Old 10-03-2011, 08:11 PM   #1
Creat-a-breeze
Flagstaff 23 ft. t/t has a create a breeze fan in the bathroom that stopped working.
There is what appears to be a thing that looks like a resistor underneath a screen that may be defective ( a rain sensor????). When I short out the leads to this, the fan works. My multimeter shows 12v across the leads.
Any ideas?
Epat is offline   Reply With Quote
Old 10-03-2011, 09:02 PM   #2
acadianbob's Avatar
Might be a built in fuse? Have you checked?
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 10-03-2011, 09:05 PM   #3
Boyd's Avatar
If accessable, check the wires connecting the sensor.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 10-03-2011, 09:11 PM   #4
2007 WildCat 32QBBS
18CrewDually's Avatar
the windings you see are resistors for the different speeds. I had a problem with the activation switch that turns the fan on when you open the hatch. It's accessible from the roof. The switch is the ground for the motor.
18CrewDually is offline   Reply With Quote
Old 10-03-2011, 09:20 PM   #5
Coops1's Avatar
I had the same problem.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 10-04-2011, 06:23 AM   #6
Fuse is good and the fan works on all speeds if I create a short across the leads to the thing that may be a rain sensor.
I guess my question is "is this a rain sensor and would there be any long term damage if I just connected the leads permanently"
Old 10-04-2011, 06:42 AM   #7
Boyd's Avatar
I would think you'd have no problems....But, first I'd give the company a call. I've delt with them in the past and they did everything possible to be of service.
Phone
810.724.3818 or 800.521.0298
