Old 08-09-2013, 03:16 PM   #1
Damage to Fiberglass panel around hitch on fifthwheel
The panel that surrounds the fifth wheel came loose from the attached trim and sustained damage on our last road trip. Is this a repair that we should try ourselves? If so, where can we buy the fiberglass panels? My husband is a do-it-yourselfer, but I wasn't sure if this might not be beyond our scope.
dglover521 is offline   Reply With Quote
Old 08-09-2013, 05:23 PM   #2
H2oski
Can you post a pic? I'm sure it would help getting good info.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 08-11-2013, 09:53 AM   #3
I have attached a photo of the area that is damaged. We had to put tape on it for the trip home to keep it from getting worse.
Thanks for any suggestions
Old 08-11-2013, 10:27 AM   #4
slide5r4fun's Avatar
Is your RV still under warranty? If so, I would have that checked out. I would be suspicious that the problem is greater than a panel coming loose, like water intrusion.
Kevin & Janine
2006 Dodge 2500 Megacab CTD 2WD
2012 Palomino Sabre 32RCTS
Pullrite Superglide 16K Hitch
slide5r4fun is online now   Reply With Quote
Old 08-12-2013, 07:18 AM   #5
No warranty and we suspect water also, perhaps from an earlier time. We really are looking to trade, but need to repair this damage before upgrading.
Old 08-12-2013, 04:32 PM   #6
Which model is it?
albuilder is offline   Reply With Quote
Old 08-12-2013, 04:45 PM   #7
Grand Surveyor
hitch, wheel
