Old 09-16-2013, 02:41 PM   #1
brockhals's Avatar
Damp interior?
We store our TT in a storage unit so it's out of the elements, but not climate controlled. The first night we stay in the camper, the sheets, etc are damp. We don't notice it as much on the second night after the AC runs but even clothes that we lay out that evening are damp in the mornings. Windows are closed, vents closed, etc. where would this be coming from? Could it be a slide issue? No problems with rain getting in
Brock
2007 Coachmen Capri - 300QBS
2012 Yukon Denali Tow rig
brockhals is offline   Reply With Quote
Old 09-16-2013, 02:57 PM   #2
jtstromsburg's Avatar
I think it would help to leave a ceiling vent oPen during storage. Also use damprid or another dehumidification product. Mines stored out in the elements, but I leave AC on set to 80 and/or a small space heater on low. I an probably wasting money on energy, but it makes me feel better for some reason.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 09-16-2013, 07:37 PM   #3
bikendan's Avatar
your problem is "Windows are closed, vents closed, etc."
that's a sure way of causing condensation, especially if you've got the propane furnace running all nite.
you need to allow for air movement and if you have hookups, use an electric ceramic heater as the main heat source, so that the furnace only needs to come on once and awhile.
do a search on condensation here. we always keep a window and vent cracked.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-16-2013, 09:54 PM   #4
Anacortesians
Not my fault again! Despite the name, I'm not really responsible!
Frank and Eileen
No longer RVers or FR owners
Old 09-24-2013, 02:44 PM   #5
LKicklight's Avatar
Mildew
Boy, this opens up a whole lot of ideas with this problem. As most know, this summer has been extremely wet with all the rain we have had. Our Sunnybrook is parked under a 30' x 40' awning all year round and never moves. We have in the past left a couple of windows and ceiling vents cracked to promote some air movement. With all the dampness we have had, all that has done ins create a terrible case of Mildew in and around most of the interior, especially on the side that faces North. Little or now sunshine gets this coach where it is sitting. Not having this problem in the past has left us asking the question, what can we do: We looked at an Ayre Dryer 1000, these little units have great reputation and are very cost effective. Also have looked at something more expensive that gets left on all the time $$$$$$. Wondering if anyone else has had this problem with a semi-permanent docked coach. Out Crusader 5th Wheel is parked with an ADCO cover, it gets lots of sunshine and plenty of air flowing in and around, with that said, do not have the problem as with the sunnybrook:
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 09-24-2013, 03:25 PM   #6
DAISY BOYKIN's Avatar
I use a lg--------------
I had a humidity problem here in Florida in my fifth wheel until I purchased a
DEHUMIDIFIER by "LG". I did a lot of research on the subject. I finally settled
on a "LG" MODEL LD301EL FACTORY REFURBISHED. It is brand new right out of the box with a 90 day warranty. Processes up to 30 pints a day set at 55% humidity control. I simply set it on the kitchen counter, hooked a drain
hose (short) to it with the discharge into the kitchen sink. Once a week, I open the gray dump valve to dump the clear clean water on the ground.
They are available at LOWE'S & Home Depot for over $200.00 for the same model new. I purchased mine from ROXSAT SHOPPING for $129.00 plus
$16.50 for ground shipping.
I'll repeat, it is brand new right out the box! Somebody did not know how to work it, returned it. The factory has gone through it to insure it works
properly.
And does it work, I can't believe how much water it removes in a week. I started out emptying the 30 pint bucket every 3-4 days, until I decided
it was a PITA! I hooked a short garden hose to it (fittings are supplied, no hose), stuck the hose into the sink.
The attachments are for a "NEW" LG. They are just for specs & INFO
ENJOY
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 10-14-2013, 01:22 PM   #7
brockhals's Avatar
Curious, why does the propane furnace create problems? I just got mine working and was hoping to fire it up this weekend
Brock
Old 10-14-2013, 01:27 PM   #8
BigTJohn's Avatar
It's the water vapor from the furnace. It just adds a bit to the inside.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 10-14-2013, 02:04 PM   #9
bikendan's Avatar
yep, a by-product of burning propane, is water vapor. and when you have your RV buttoned up like an airtight Tupperware product, that along with the humans breathing out water vapor, will quickly cause condensation.
Old 10-16-2013, 08:03 AM   #10
brockhals's Avatar
so if I leave the vents cracked and a window or two I should be alright using the propane heater?
Brock
