08-10-2021, 08:43 PM
#161
Some folks have been ordering the Goodyears and having a local tire shop install them.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
08-10-2021, 08:51 PM
#162
Originally Posted by Tireman9
Actual tire type & size and actual scale reading for the loading would help.
Since there are no "8-ply" or "6-ply" tires I can't help without appropriate numbers.
Actual tire make/size is Castle Rock, size ST205/75-14 (photo attached). And just repeating what the RV service center indicated. Here's the quote from the email I received:
The only 8 ply tire in that size that I can get right now, is a Towmax STRII. I can get some Carlisle tires, but they are only 6 ply.
"It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be the way."
Tow Vehicle: 2013 F-150 FX4 5.0L V8 w/ Lift Kit & Towing Package
TT: 2019 Wolf Pup 16BHS
08-10-2021, 08:55 PM
#163
OR, in urban and suburban areas, like Chino, CA, the local America's Tire(Discount Tire outside California) had 215 70/14 in stock when the kids needed new tires Saturday. I got our last 225 70/15s there, in stock. Other sizes they tell us five days to get em ordered. Seems like with some planning .
08-11-2021, 07:57 AM
#164
Go to a Goodyear store. Order from them.
2013 Flagstaff 831FKBSS
08-11-2021, 08:06 AM
#165
Nothing wrong with going to the Carlisle. It’s a quality tire.
Regi, Betsy and Juniper
2016 Rockford Roo 19
2014 Ram 1500 Tradesman Crew Cab 3.6 6cyl w/ 3.55
2018 Coachmen Freedom Express Liberty edition 279RLDSLE
2014 F150 Ecoboost Supercrew with Max Tow
08-11-2021, 08:13 AM
#166
I installed Goodyear Endurance after a China Bomb caused $7000 in damage.
https://www.forestriverforums.com/fo...me-229790.html
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
08-11-2021, 08:36 AM
#167
Canadian Member
Originally Posted by knight1fox3
Just curious if anyone has any feedback on the performance of a Towmax STRII type tire (8-ply). I'm looking to replace the original Castle Rock tires on my RV and was hoping to go with Goodyear Endurance but those are not currently available in my area. The RV service center I typically use also noted they could get a Carlisle tire but that it was only 6-ply. Not quite sure what the implications are of that and would appreciate any feedback. Thanks in advance.
Your Wolf Pup is probably in the neighbourhood of 5,000# fully loaded (an actual scaled weight would be helpful) and it has a single axle. Ignore the “ply” rating and look at the load range of the tire to make sure yours can handle a lot more than they’re being asked to carry. Your picture shows you have Load Range D Castle Rock tires that are supposed to be good for 2540# each (5080# on the axle) if inflated to 65 psi. If you have plenty of safety factor with the OE Castle Rocks you may be fine. IMO, the Castle Rocks are more of a concern when you have a heavier trailer, live in the hot southern states and/or you tow on a lot of poor roads or dirt roads. That said, I admit I did swap mine out as insurance. The Goodyear Endurance tires I put on are a lot beefier than the same Load Range E Castle Rocks that came from the factory.
08-11-2021, 09:31 AM
#168
Commercial Member
If your OE tires as shown on your RV Certification label is ST205/75R14 LR-D then you should NOT go to LR-C tires.
If you had "golf ball" size bumps or bubbles on the tire sidewalls those would be indication of impacts and broken body cord and not any condition built into the new tire.
I covered impact breaks in my blog, with pictures. Here is a link to the posts on the topic of impacts.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
08-11-2021, 09:41 AM
#169
Towmax is what FR used to put on a lot of campers before they "upgraded" to Castle Rock. I always have changed mine out to Maxxis.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
