Old 02-23-2016, 11:59 AM   #1
hawki8624's Avatar
Date to dewinterize in iowa
Hi I need help. This will be my first spring with the new rv. I live near Iowa city Iowa and was curious when would be safe to de winterize. Would I be ok to do it around march 23rd as I have a shot at a light camping trip for a few days but I want to wait until it is safe to leave water in it so I don't have to winterize again.
hawki8624 is offline   Reply With Quote
Old 02-23-2016, 12:04 PM   #2
rmac04401's Avatar
Each year is different. I would watch long range forecast and when it is forecasted to be above 32 degrees consistently you should be safe to de winterize. It's all in a persons risk taking. Does not take long to winterize and de winterize. I myself would go camping then winterize again until temps stay above 32 degrees
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
Old 02-23-2016, 12:29 PM   #3
I am in cedar falls. I do mine about April 1 every year been safe so far.
If u go early just watch the weather...if drops below 35 turn the furnace on at the lowest setting.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 02-23-2016, 06:08 PM   #4
hawki8624's Avatar
thanks for the help
Old 02-23-2016, 06:50 PM   #5
We aren't that far north, but we do the winterize/de-winterize thing as needed. We de-winterized just last week for a 3 night trip where we could find 40 degree days. Re-winterized before leaving the CG. If you are setup right, you can winterize a TT in about 20 minutes. If you blow out the lines, a good bicycle pump is all that's needed. We use RV antifreeze and don't blowout the lines.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 02-24-2016, 11:58 AM   #6
hkreck's Avatar
I'm in Co. Bluffs like cfiowa I de winterize around April 1st, the weather is getting warm enough by then that even if you get a cold day as long as the system is still drained should be good to go.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
winter, winterize
