Old 07-26-2009, 07:39 PM   #1
Day-night blinds
How can the blinds be made to slide easier on the two strings they travel on?
They are real hard to move up or down.
fmielke is offline   Reply With Quote
Old 07-26-2009, 08:43 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
We've used ours for almost three years and they're still tough to move but are better than the first trip. We don't move them very often but they do get easier over time. You don't want them too loose or they'll constantly fall to the bottom.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-26-2009, 09:11 PM   #3
powerboatr's Avatar
if you
hold tightly on the strings
then loosen the screw that holds the lower part of the strings to the wall
then let out a little slack
do it even on both sides
the tighter they are the stiffer they are
the slacker the strings the LOOSER they go
its a balancing act , you adjust them to suit your needs
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
