04-01-2015, 09:41 AM
Day/Night Blinds
It seems that way back when, somebody told me that when you are towing your trailer that the blinds/shades/curtains should always be in the fully "up/raised"" position. I can't remember what the reason for this was. However, lately I've noticed that the the majority of trailers I see being towed have the blinds/curtains in the "down" position.
I'm just curious what the majority of your out there do with your trailer blinds/curtains when you tow? Up or down? Also, was anybody else told to tow with the blinds in the "up" position and if so do they remember why they were told this?
I always put mine in the "up" position when I tow. While not a major PIA to do, it's just one more pre-tow item to take care of and once you arrive at your campground then you have to go around the entire trailer and lower all the blinds. Again, not a major deal, but something I'd prefer not to if there is not justification to do.
04-01-2015, 09:52 AM
Day/Night Blinds
The best thing we did with them was replace all of them with venetian blinds.
04-01-2015, 09:53 AM
Following
04-01-2015, 09:59 AM
Actually, your second thread was deleted, as multiple postings are not allowed. If you need to move a thread, the best way is to contact a site team member who will be happy to oblige the request. This way, it keeps replies and such in the proper order by time stamps.
I'll get it all sorted out, as it may take a little bit.
EDIT: Should all be good now. Replies from both threads have been merged and the second OP deleted, and the first OP moved to general discussions.
2011 Flagstaff 831 RLBSS
04-01-2015, 10:12 AM
Back when blinds were all aluminum this was the standard recommendation because the blinds could jump out of the wind holds (clips on bottom rail), and the swinging blind could pull the hanging brackets from the wall or allow the blind to swing into the glass causing breakage considering regular plate glass was the standard.
04-01-2015, 10:21 AM
This is the 3rd camper with alum venetian blinds(2 from factory) and we've never had that happen.
04-01-2015, 10:37 AM
I'm with you. Just relaying the "why" as used to be relayed during delivery. I personally have always traveled with ours closed. Last two campers of ours only had an aluminum blind on the kitchen window. Rough road did cause the HTT's blind to jump out of the wind holds once in 8 years of travel, but no damage from it. Given the number of campers I've encountered with window breakage while on the road, I rather mine stay down if nothing more than acting to constrain the shattered glass from being a larger mess to clean up inside, but that's me.
04-01-2015, 02:44 PM
Thank you.
04-02-2015, 06:03 AM
We keep our blinds down when traveling to reduce fabric bleaching from the sun.
2015 Silverado gas ext cab 2500
2014 Flagstaff 8528IKWS
04-02-2015, 06:12 AM
Ditto! Having the blinds down also helps to keep the trailer cooler (less hot) in the summer.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
04-02-2015, 07:39 AM
Big difference with the blinds down, just make sure they are aluminum blinds, and not vinyl. We melted our vinyl blinds while in Arizona this past February...
Rick
2015 Work and Play 30WRS
2011 Ram 2500 I-6
04-02-2015, 09:35 AM
I am with the blinds down crowd. Store with blinds down to help protect from the sun and see no reason to raise for traveling.
I have the cloth day/night shades.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
04-02-2015, 10:13 AM
I like the idea of leaving them down to reduce fabric bleaching of the couches, etc and keeping the inside cooler. Great ideas. Thanks for the responses.
04-02-2015, 10:29 AM
When we purchased our first set of day/night cloth blinds they told us to keep them up, so they kept the pleats.
We're in the process of replacing ours with MCD shades, much better product and no strings to fray and break.
Donna and Bob (retired USAF),
fur babies Casey (mix), Lucy and Loki (standard poodles)
had a 2015 Rockwood 8281 WS - traded for another brand.
2016 RAM 3500
