Old 02-16-2015, 02:22 PM   #1
JCamper's Avatar
DC 12v question
So I know that when I had my MaxxAir fans installed the dealer just tapped into a nearby light in the ceiling. With that said, my question now is, I'm looking to tap into the nearby 12v cigarette plug to wire in a 12v TV, and am wondering if I do that, will I still be able to plug something into that cigarette lighter plug (like a phone charger) to charge, or will the draw be too much and potentially melt wiring?
How do I guage when tapping into the 12v DC wiring how much is safe and when to back off?
Thanks,
South Jordan Utah
2013 Prime Time Tracer 3150 BHD
2011 Ram 2500 Laramie Diesel
1 Ol' Lady
3 Girls
1 Boy
JCamper is offline   Reply With Quote
Old 02-16-2015, 02:43 PM   #2
Flybob's Avatar
You will not melt the wiring., that's what fuses are for. Check the value of the fuse for the Cig lighter circuit probably 10-15 amps. Cell phone charger draws about 1 amp, but there may be other things as well on that circuit, Check wiring schematic or pull fuse and see what does not work. A small 12V TV should be fine.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-18-2015, 04:31 PM   #3
JCamper's Avatar
Thanks Flybob I will be installing an inline fuse.
Apparently nobody else has any input?
South Jordan Utah
1 Ol' Lady
3 Girls
1 Boy
Old 02-18-2015, 07:35 PM   #4
HONDAMAN174's Avatar
Might not even have to use a 12v TV. I bought a 24" led TV and a seperate Blu Rey player and combined they pull 65 watts. I installed a 400 watt inverter to provide power even though probably won't go over 100 by tapping in to the 12v power supply in entertainment center. Has own on switch so can turn off and not have parsidic draw. All on a 15 amp circuit.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
