Old 04-15-2012, 07:09 PM   #11
BicycleMark's Avatar
Low Point Drains
You should be able to locate the low point drains fairly easily. Look for 2 hoses sticking out from the bottom of your trailer. They should be abour 3/4 inch diameter. Often one is red and the other white. They will be next to each other. Once you find the hoses, look in the trailer at their matching location. There should be their mates coming up through the floor with a shutoff valve on each.
Luck!
BicycleMark is offline   Reply With Quote
