03-08-2016, 03:22 PM
Retired
De-Winterizing / Summerizing TT
We will be "summerizing" our TT at the end of this month when it appears from hibernation. I have read through the many Threads and the FR video dealing with this subject but no one has mentioned the disposal of the drained diluted pink stuff. I might be over thinking this.
How do y'all handle the disposal of the "pink stuff"after you have completed the process?
Thanks for the inputs.
Happy Trails
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
03-08-2016, 03:35 PM
RV antifreeze is non-toxic.
It can be disposed by pouring down the drain or sewer.
And while I probably wouldn't, it can be dumped on the ground with no ill effects to the environment.
Automotive antifreeze IS TOXIC. DO NOT do the same with it.
03-08-2016, 03:36 PM
I usually just flush it out of the faucets into the waste tanks, camp and then dump at the dump station like normal.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
03-08-2016, 03:41 PM
Further note, if it were toxic or harmful or needed special disposal why would we put it in our camper freshwater lines?
03-08-2016, 03:51 PM
Retired
Thanks for the help...much appreciated
2017 Columbus 340RK
03-08-2016, 03:54 PM
Retired
SuicideSaints,
Good point
how did you come up with your "handle"?
2017 Columbus 340RK
03-08-2016, 03:56 PM
It is not harmful to pets if you do happen to drain it on the ground, most folks just flush it to the waste tanks. Run plenty of water thru your system to ensure there is no after taste
Retired Navy
2016 Flagstaff 26 FKWS
03-08-2016, 04:05 PM
I would bet the farm that someone, somewhere is using something like methanol or similar to winterize.
John.
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
03-08-2016, 04:07 PM
Originally Posted by MainelyUS
SuicideSaints,
Good point
Back in my younger (not so smart days) I used to think I was invincible. I was a member of a dirt bike racing team, that morphed into a street bike (sportbike) racing team, that eventually morphed into a street bike stunt team. The team name was "suicide saints". I just kept using the name.
03-08-2016, 04:19 PM
run it out on the Ground, is what I do
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
03-08-2016, 04:50 PM
Theeeeeen sanitize the system when your done!
But before you un bypass the water heater.
1/4 cup of bleach per 15 gallons of water
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
03-08-2016, 06:15 PM
Left Coast
Follow the sun...don't use the stuff!....
03-08-2016, 09:55 PM
Bob... you'll just wind up burning your retinas.
03-09-2016, 01:29 PM
I spilled some/ not much on the grass last year dewinterizing. While the grass game back finally it didn't like it much.
03-09-2016, 07:06 PM
No problems with RV antifreeze. Non Toxic just flush well and drain on the ground, or at the dump station.
Brandon2
2014 Sun Seeker2500TS
03-09-2016, 08:22 PM
Last year my DH drained into a container and took it to our recycle center for disposal.
03-10-2016, 09:32 AM
And they probably pored it out on the ground !!!
LOL !!!
