Old 06-21-2015, 06:17 PM   #1
Dehumidifier
Hello all,
Looking for the appropriate size dehumidifier for this winter in Pennsylvania. 30' Salem on a permanant site, will be using most of winter. Any other advice on moisture removal would be appreciated!
Thank you all,
Rich
rich518 is offline   Reply With Quote
Old 06-21-2015, 06:25 PM   #2
Flybob's Avatar
Be aware most dehumidifiers ( compressor driven) do not work well below 40F. I use a 30 pt in mine when temp is above 40. I run the drain into the shower and dump grey tank once every 2 wks. I ran a separate #10 20ft extension cord so I do not have to leave converter plugged in ( lots of storms).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-21-2015, 06:25 PM   #3
Send a message via MSN to Tiggerdad
I have a 30 pint from Sears. A little larger than necessary. Has adjustable humidity settings and 2 fan speeds. Our winters are not extremely cold but very humid and lots of water in the air with people and especially when using propane. If you have sewer you can let drain in the sink with dump valve open.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 06-21-2015, 10:14 PM   #4
SandeeAR's Avatar
I didn't want another appliance that I had to deal with/dump. I go to Dollar Tree and buy the generic Damp Rid containers for $1 each. We are in a 25' Class C. I put one in the bathroom, closet and cab floor. I put one in a bay that has propane bottles and bug sprays, etc. I change them as needed. Usually about every 4 months.
Sandee Melton
Currently: 25' Tioga Ranger 2008
Hoping soon: Forester 3011DS
Sent from my iPhone
SandeeAR is offline   Reply With Quote
Old 06-22-2015, 08:48 AM   #5
After trying 2 DriZair containers (similar to Damp Rid) I found they don't remove enough moisture (Live in Orlando the most humid place on earth). They would probably work in a small room or closet. I decided to order the one below. It can be drained into the tub and can be set to shut off at a selected humidity level. I will post a review later.
Amazon.com: EdgeStar Energy Star 30 Pint Portable Dehumidifier - White: Home & Kitchen
Brewhedd is online now   Reply With Quote
Old 06-22-2015, 09:00 AM   #6
Ret E-9 Anchor-clanker
donanddona's Avatar
I too run a Sunpentown SD 65e dehumidifier. Although large it does a great job. We run it mostly when the ceramic heater is operating. It has worked every well for three years now.
Name:	Sunpentown SD 65E Dehumidifier.jpg
donanddona is offline   Reply With Quote
