Old 01-31-2015, 04:25 PM   #1
Dehumidifier Advice
Good Day all-
I have a 33' salem on a permanent site and for the first time will be using it all winter. I'm looking at a Frigidaire 50 pint dehumidifier which draws 4.8 amps, and features continuous drain. I'm not an electrician but specs state it's 115V which I believe from a practical standpoint doesn't mean too much for my purposes, it may be the same as 110V? is this true?
Also, this unit is bigger than I need and weighs in at 37 lbs. Is it practical to leave on counter space when in use so I can drain into the sink?
Any useful commentary would be appreciated. Thank you
rich518 is offline   Reply With Quote
Old 01-31-2015, 04:58 PM   #2
Mojojojo's Avatar
We purchased an Ivation off Amazon like $80 ish , works ok in our monstrously big 355 and are going to purchase at least one more. We live in ours as well
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 01-31-2015, 04:59 PM   #3
Flybob's Avatar
115VAC and 110VAC you are OK with either. If you are concerned about leaving on a counter, set it on a short platform and run the drain into the shower. I did that until I finally added a drain hose that runs through the enclosed bottom and out on the ground.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-31-2015, 05:20 PM   #4
Thanks Flybob that puts my mind at ease. Drainage issue the biggest problem.
Thank you
Old 01-31-2015, 05:21 PM   #5
Thanks Mojojojo.... I saw that one also. been looking at several
