Originally Posted by yakmeat123
Why do you now think that wouldn't be a good idea
Because the water that is captured in the trap will freeze and the hose will no longer drain. Then, the bin inside of the dehumidifier will fill and (hopefully) turn off the dehumidifier, but it will likely freeze, also, then split the bin. When it warms-up, the bin will empty, and if the dehumidifier turns itself back on because it “thinks” there is no water in the bin, the water will spill out of the splits in the bin and dump onto the floor or wherever you have placed the dehumidifier.
Bruce
