Old 12-04-2015, 04:34 PM   #31
onetonford's Avatar
Putting the control center inside the pantry cabinet with the main cabin light switch inside.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 12-04-2015, 04:58 PM   #32
My 2009 Flagstaff 26RLSS Super Lite had a furnace exhaust that would be covered up by the rear entry door if the door rested on the side of the camper after opening. After melting 2 doors (1 during the pdi) FR attached a shock so the door can only open up 3/4 of the way. I noticed on the current 26rlss and rockwood 2604's they still have the exhaust by the rear entry door with a shock on the door.
2013 Salem 30KQBSS TT
Equalizer 4pt Hitch system-12K
2016 Ram 1500 Crew Cab Sport 5.7 Hemi w/8 Speed
Great Laker is offline   Reply With Quote
Old 12-04-2015, 05:08 PM   #33
5er_tom's Avatar
My Wildcat has the roof water drip spouts. Problem is the one on the front drivers side drips on top of the bedroom slide. We hear a lot of complains of leaky bedroom slides on the Wildcats. This spout placement sure does not help!
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 12-04-2015, 05:25 PM   #34
not liking the height of the new 5er - new one is 13'5, old wildcat was 12'5
pushing more wind ie less mileage.top cabnits are hard to access without a ladder.
Also water filter hidden behind the fireplace- 4 screws to remove fp but just saying
riverrat958 is offline   Reply With Quote
Old 12-04-2015, 05:36 PM   #35
My door opens the other way. Maybe you should get your's swapped to open from the other side.
2011 Traverse LT, 3.6L, FWD
Old 12-04-2015, 06:15 PM   #36
Pop up tv leaves remote sensor below table level.
I guess this is just something to live with. Our new Rockwood Signature 5er has a great tv with good reception, but to use the remote control you need to get up and point it down into the cabinet to hit the sensor. Any mods for that??? I couldn't find a way to adjust it higher.
Old codger is offline   Reply With Quote
Old 12-04-2015, 06:17 PM   #37
Try bouncing it off the ceiling.
Old 12-04-2015, 06:20 PM   #38
Stormrider151's Avatar
LCI control boards and slide control boxes mounted behind stapled panels in places you would never think to look for them. I asked the dealer (should have ask my dog) no luck there. Finally found them using the remote control and listening for the relay click. Two days.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 12-04-2015, 06:20 PM   #39
Originally Posted by DavidH View Post
More details on the wireless switch, please?
This .....is what I (& others) use.....can be programmed as "Three/Way" also....
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 12-04-2015, 06:55 PM   #40
realebill's Avatar
On my Rockwood all the trim and lighting and acessories are held on with steel screws. It would probably cost an extra $20 to use stainless.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
