Old 12-04-2015, 07:10 PM   #41
schrederman's Avatar
Originally Posted by realebill View Post
On my Rockwood all the trim and lighting and acessories are held on with steel screws. It would probably cost an extra $20 to use stainless.
They won't use stainless because they won't work with their magnetic tips...
My Surveyor has TorFlex axles... which are fine. However it sits so low that it drags easily... very easily. They make a mod to raise it 3" but they want over $200- just for the parts... i.e. a couple of pieces of steel and some bolts... really?
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 12-04-2015, 07:15 PM   #42
Originally Posted by tande View Post
This .....is what I (& others) use.....can be programmed as "Three/Way" also....
Doesn't this need 110VAC to work? Wouldn't work for 12VDC lights?
Edit
Nevermind! I see they have a 12VDC receiver.
2011 Traverse LT, 3.6L, FWD
Old 12-04-2015, 07:27 PM   #43
Microwave at ceiling and medicine cabinet mirror to high for my wife to use. Ding table wobble, I am thinking a third table leg.
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring
FrankMor is offline   Reply With Quote
Old 12-04-2015, 08:42 PM   #44
Tfort's Avatar
Curb side pass through storage doors have 2 locks one top one bottom and a thumb lock in the center but all on the same door so you have to lock the door to keep it closed and the thumb lock is worthless.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 12-04-2015, 09:26 PM   #45
Oh yeah- my camper came with the fold down free standing table. I installed 3 legs and its rock solid now. Another pet peeve- having a gutter seam where the awning is located which tends to cause a drip under it.
Old 12-04-2015, 09:28 PM   #46
schrederman, At Goshen this year FR installed those spacers to raise my TT at no charge. My tires only had about 1" of clearance from the body.
While they were under the TT they replaced all of the liners and seals associated with wheel wells and sliders. You might be able to get the same service if you attend next year.
Travel safe
2001 Ford F-350 Super Duty CC Dually, 7.3 Diesel
2011 Cedar Creek 36CKTS Touring Edition
FordHauler is online now   Reply With Quote
Old 12-04-2015, 09:36 PM   #47
Done with this
In our 252RLS, there is no drawer for silverware. In other models with the same cabinet setup, there is 3 drawers...
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 12-05-2015, 11:57 AM   #48
We bought a utensil caddy at Sams that has 3 utensil spots plus holds plates and napkins. Might be a good solution.
Old 12-05-2015, 12:27 PM   #49
Done with this
Thanks. That's what we did, it is just taking up a lot of shelf space under the sink. Most other models have 3 small drawers on the flat part of the cabinet by the door under the sink. That's really the only gripe, so I guess it ain't so bad.
Old 12-05-2015, 12:30 PM   #50
abomb's Avatar
Originally Posted by Stormrider151 View Post
LCI control boards and slide control boxes mounted behind stapled panels in places you would never think to look for them. I asked the dealer (should have ask my dog) no luck there. Finally found them using the remote control and listening for the relay click. Two days.
X2....I had to do the same thing. My landing gear fuse blew for the outside switch, but it would work with the remote. No mention of these fuses in my manual. I traced the clicks. Under the large draw under my sink was the control box with 5 fuses. Had to remove draw to replace fuse.
2015 Palimino Puma 295 BHSS
Anniversary Edition 5th Wheel
2006 Ford F250 Diesel
abomb is offline   Reply With Quote
