Dewinterizing water not working
Hello folks,
I have a slight problem and I am looking for some help or advice,
I have a Rockwood Roo 21SS.
I normally use it at RV parks around my area, (North East) they have water hook ups at these parks
I have dewinterized it this last weekend but I don’t get water pressure to the sink, or bathroom
I have filled the water tank, and the pump seems to be working, and yes the hot water tank is empty,
Here is what I have done,
1) Hot water tank – hot and cold valves are open, bypass valve is closed
2) Valve at the bottom of water tank is open- water feed from tank?
3) Valve at the water pump is open
4) I have filled the clear water filter and put new filter in.
5) Turned pump on, seems to run fine
Results
Limited air pressure in the water lines. Once I open the faucet the air pressure escapes and then I lose all pressure, this takes about 1 to 2 seconds.
The water from the clear filter seems to pump through the sink and then it does not refill.
Does not seem to get any water at all to the hot water tank.
Is there a valve I am missing? I don’t know if there is a valve to switch from street water(that I normally use) to the onboard water tank?
Thanks for any insight or advice ,,
Rockwood Roo is working out better than I ever expected.
2012 Rockwood Roo 21ss
TV- 2015 Dodge Ram 1500 w/tow package
