Old 09-15-2019, 07:31 PM   #1
larry2c's Avatar
Didn't expect this one
Today I went out to the wife's car in the driveway to get some packages she had in there. I heard a noise that sounded like a propane tank when you are running the furnace or other high BTU thing. I walk over to the traler (on the side of drive) and open up the inspection flap on the propane tank cover. The picture below is what I found!
I closed the valve and that quieted things down. I haven't checked the tank to see how much I lost yet but it was close to full before this happened. I've never seen this happen before but I'm guessing it was a combination of a cr@ppy swedge on the hose fitting and the 100 degree heat today. glad I caught it but still pretty shocking.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 09-16-2019, 11:03 AM   #2
Head Rambler
It doesn't happen very often, but it does happen. The good news is that you found it before anything bad happened, and a couple new pigtails will fix it.
Gotta go campin!
Old 09-19-2019, 10:18 PM   #3
On our mini lite it did the same thing about 6 months after we purchased it. We lost almost a full tank.
Malojeer is offline   Reply With Quote
Old 09-22-2019, 06:59 AM   #4
rp53's Avatar
had the same thing happen not once but twice
2017 Micro Lite 21FBRS
2017 GMC Sierra double cab Z71
rp53 is offline   Reply With Quote
