Old 10-09-2016, 02:56 PM   #11
Head Rambler
I searched for that error code, but can't find anything on it.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 10-09-2016, 03:09 PM   #12
toslow's Avatar
Originally Posted by Pleasantsurroundings View Post
Sounds to me like the turbo booster boot came off.......why do I think that.....ours came off three times on our way to FL. Finally had to have the Ford Dealer put new clamps on it.
Really, how would this set a water in fuel code?
this might help you out
http://www.newyorkbussales.com/wp-co...DE-UPDATED.pdf
haven a blast
toslow is offline   Reply With Quote
Old 10-09-2016, 03:57 PM   #13
Never mind....😃
Pleasantsurroundings is offline   Reply With Quote
Old 10-09-2016, 05:38 PM   #14
FrankG's Avatar
Polked around the internet and found references to the 97 3 Cummins engine fault code. Water in Fuel Signal voltage high, "no effect on engine performance"
I think you need to look elseware, in the morning you should be able to talk to a Cummins service center and get some professional guidance.
Good luck and enjoy the evening.
2016 Vengeance 29V
2013 F250SC 4x4 gas
Blue OX W/1500 lb bars
2012 Spyder RTL
FrankG is offline   Reply With Quote
Old 10-09-2016, 08:07 PM   #15
Get the fuel filter replaced asap! I hope you can do it yourself. It is not difficult to do. Anytime a diesel acts up, replace the fuel filter before looking elsewhere.
This and other threads remind me of the importance of the ability of DIY maintenance especially on diesels. One won't always be near a maintenance shop to help.
BTW, each of my 3 diesels always has a spare fuel filter in the vehicle just in case. Not too long ago, I got bad fuel which clogged 2 fuel filters and caused the vehicle to go into limp mode when using pressing the accelerator pedal past the 1/2 way point.
Skyliner is offline   Reply With Quote
Old 10-09-2016, 08:37 PM   #16
Bluepill's Avatar
If you have a spin-on filter, check this video so you don't miss the o-ring ......
https://youtu.be/yzkw720STeU
This is part 1 - The actual filter change/prime sequence
https://youtu.be/jJJcZb1lmug
2008 Itasca Meridian 37H
Old 10-09-2016, 08:40 PM   #17
After reading your description about how it if running, sure seems like you ma have a fuel system that is getting air in the system. As TonyD stated, replace your fuel filter first thing with new "O-Rings". Sure hope it is something this simple. I have seen slimier problems like this throw all kind of codes.
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 10-10-2016, 02:43 PM   #18
Update
I've ordered a new fuel filter which is scheduled to be here tomorrow morning. In the meantime, thanks to a friends suggestion, I loosened up the filter slightly and had my wife turn on the key. Fuel flowed out of the opening where I'd loosened it. I then re-tightened the filter and started the engine. It purred just like it's supposed to. We left our gravel parking lot and drove down the road a couple miles to an RV park. Much nicer than the gravel parking lot. I have a feeling that there was air in the fuel line and now it's out due to what I did. I may not put on the new filter unless there is more problems, but at least I'll have it with me, which I should have had in the first place.
I'd like to thank everyone that replied and gave suggestions. Ps. There is no longer a check engine light or any scanguage codes. My wife, my dog, and I are smiling again. Stan
StanDonna is offline   Reply With Quote
Old 10-10-2016, 03:57 PM   #19
Great news!
Old 10-10-2016, 07:14 PM   #20
Yay!😃
diesel
