Old 04-08-2014, 01:44 PM   #1
Cudaman's Avatar
Dinete Cushions
Just had my first outing with the sc226rbds and I needed to make up the bed in the dinette area. Thought this would have been an easy process but there is either a 3 or 4 inch gap at the outside or the inside as you puzzle in the cushion pieces. Obviously we made it work but I have seen some others post relative to this same problem.
A quick solution I see is the back wall cushion needs to be that much taller so it fits in the space correctly. Ive heard some customers have been supplied cushions from FR. Any other thoughts?
Cudaman is offline   Reply With Quote
Old 04-09-2014, 08:46 AM   #2
cat1956's Avatar
My problem was my back cushions were over an inch thicker than the sit cushions. I contracted FR and they replied that I should be able to come up with a solution to the problem myself. Not what I was wanting to here. But anyways I ordered a pre cut cushion with the measurements that we needed for $46.00. That included shipping. We just use it as on need to be bases.
Tommy and Wanda
2014 Flagstaff 27RLWS
2017 Ram 1500 5.7 Hemi
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
