Old 09-14-2009, 03:39 PM   #1
UNIT6AUBURN's Avatar
Direct TV Dish
Got a new direct dish and receiver.Trying to hook it up and I need some ideas on a portable stand or something.
UNIT6AUBURN is offline   Reply With Quote
Old 09-14-2009, 04:37 PM   #2
Hipshot's Avatar
I found this on another forum, looks interesting.
http://www.bbrv.dreamstation.com/sat.html
Hipshot is offline   Reply With Quote
Old 09-14-2009, 06:37 PM   #3
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
I built one of those in the link above from PVC and it worked great. It would only pull in ONE sat in the backwards position with a dual LNB dish. (without moving the position of the dish)
When I used a dual LNB dish, I simply screwed it to a square piece of plywood, and bolted it down. I used my Equal-i-zer bars to hold weight on it. Simply set it on the ground, and leveled by putting a stone or something under it when needed. No fancy mount is really needed if you have room to store it like this. If you need to take it apart to travel...simply replace the nuts on the dish with wingnuts so you can loosen them without tools...very slick.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 09-16-2009, 09:47 PM   #4
Bought a tripod from radio shack $30. Run pvc pipe thru to hold dish and stake thru hole in bottom of legs. Works great and stores easy too.
2010 F-250 FX4 V-10
2010 ROCKWOOD ROO
2002 YAMAHA G19 ELEC. CART
1962 Gorgeous Wife
1-spoiled & loving dog "Rocky"
MelloDano is offline   Reply With Quote
Old 09-22-2009, 09:23 AM   #5
Direct TV 5LNB
I have the new 5 lnb dish and it is too large for the standard tri-pod. I got a suveyors tri-pod and adapter on EBAY for around $50.00 and it works great.
Charlie
Boisegolfer is offline   Reply With Quote
