Old 03-22-2012, 09:35 PM   #11
I actually purchased two standard receivers from Direct TV or our 5er. We use a 18"x20" dish with 3 LNP's. I ran one cable from the dish to the satellite connection at the trialer and installed a 2-way splitter just before the entertainment center so I can run a cable into the front bedroom for the second receiver.
Ed & Laureen
2005 F-250 4X4 SD 6.0 Powerstroke
2009 Cherokee Wolf Pack 285wp (the side door ramp toy hauler)
nailit is offline   Reply With Quote
Old 03-22-2012, 09:58 PM   #12
GASPEDDLER's Avatar
Originally Posted by phrogdriver93 View Post
I was on the phone with the Direct TV tech reps today aling with their satellite referrals. I was told you need a Standard definition receiver in order to use the simple 18 inch dish. Receiver model numbers should be either a D11, D12 or D13.
I wanted to use my H25-100 receiver from home as well, but I just don't think the eqpt is compatible. I'm going to have to either exchange/return or purchase a compatible Standard def receiver.
You can only get Std def with the 18 in dish.
The H-25 will only work with a SWM dish set up. Only other choice is get a different HD box like an HR20, HR21 or an SD box as you have already mentioned.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 03-23-2012, 08:43 AM   #13
phrogdriver93's Avatar
So now for the "setup" questions.....
I have an input labelled "satellite" on the outside of my TT. Am I correct to assume that all the tv's would be able to receive the satellite signal? The drawback being that with one receiver they would all be tuned to the same channel?
I'm sure DW will get used to watching The Military Channel and ESPN ;-)
phrogdriver93 is offline   Reply With Quote
Old 03-23-2012, 10:55 AM   #14
The TV that is conneted to the jack that has the booter light will be the only one that would receive the satellite signal. You going to have run a seperate cable (through a splitter) with a cable jack to any other TV. If my memerory serves me right, your satelite receiver at that same TV will have to connected the other jack that is labeled "sat" and the booter light should be off.
I installed my splitter before that paricular set of jacks (at the main TV). I guess you could install a splitter between the "sat" jack and the receiver for the other cable.
Ed & Laureen
Old 03-27-2012, 12:52 AM   #15
bush's Avatar
this is what i have found out also.
so whats the best way to go? slimline dish or a standard receiver?
the dish is more $ up front but the receiver will cost more in the long run.
if i go with the slimline dish what all do i need. the swm box that has to be pluged in all the time or just the dish and receiver?
2011 puma unleashed 298fqu toyhauler.
hauling a 2012 polaris RZRS
pulled by a 2006 chevy 3500 drw 4x4 duramax lbz
bush is offline   Reply With Quote
Old 03-27-2012, 03:39 AM   #16
Witch Doctor's Avatar
I have a new 3 LBN 18" dish multiswitch, I took my receiver out of the bedroom in the house. I tried the 1st LBN and hooked my cable to it and set the elevation, direction and used a cheap compass (@CW) that lets you set the azimuth on the compass over south (it rotates around the dial)I did not change anything and pointed it by the arrow on it , left the slimline as was set up for my home. 1st try with the compass I got all the channels that I get at home now. The only problem was the tripod tube was to small to fit the dish, so I went and bought a pvc coupling 1"1/2 or 1"1/4 and put in on as a spacer and now I can tighten the dish to it. It will come thur my speakers with setting the Gen 3.0 to AV1 mode
Witch Doctor is online now   Reply With Quote
Old 03-27-2012, 07:39 AM   #17
camper_Lucy's Avatar
To get your H25-100 to work you will need to add a SWM8 and a power inserter to the setup. Whether you chose a 18" (std only) or slimline (HD) either will work, just the setup alignment changes and the slimline takes more time to setup, but not that hard I do all the time at CG's.
Good resources;
http://www.dishpointer.com/
InstallerOasis.com
[Cached:08:21:01-08:41:01]Using my H25-500 Receiver whil | DIRECTV System Installation/Se | DIRECTV Technical Help Forums
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 03-27-2012, 02:20 PM   #18
bush's Avatar
i ordered a slimline dish kit off ebay for 80$. comes with a 4 way splitter and the swm switch. it all the same as i have here at the house so it better work. just have to be able to point the dish in the right direction.
Old 03-31-2012, 07:53 PM   #19
bush's Avatar
got the slimline dish setup to day. took me a few min to fugure out how my work Digital Satellite Finder works but i got it working.
Old 04-01-2012, 02:12 PM   #20
maxwell18's Avatar
sat set up
I just went through this and if you have a non HD receiver in the bedroom you have to cange the setting to multiswitch and have a 18 inch dish. I don't have a HD reciever so don,t know quitte how it would set up. Oh yea one more thaing is if the box is not used at all for about 30 days the Satilite quits sending the signal to the box. It just kind of shuts the box off and you have to call by phone and have direct tv to activate the box again (was no charge). Now I just go out and set my dish up every couple of weeks and let the tv run for a few hours. This way it gets whatever it needs such as updates and such. Belive me this like to have drove me crazy and wound up paying for service call to get a tech ot come out. The elvations and Azz. was all corect along with the 18 inch dish and multiswitch . The tech asked how long it was sitting since last used and told him about 2 to 3 months, BINGO that was it.
maxwell18 is offline   Reply With Quote
