Old 04-03-2015, 11:14 AM   #11
TURBS's Avatar
Originally Posted by B and B View Post
OC from my pin box to front storage is open just above the door, i would think a path to the back would be easy from there.
I've not looked @ mine I wonder to if it's open?
TURBS
08 duramax tuned n modded, 32bhok Sabre
Old 04-03-2015, 11:22 AM   #12
B and B, I'll have to look on mine. If it is, might just run enough cable to coil it and stuff in the pin box and not have a receptacle there,
Old 04-04-2015, 08:43 AM   #13
Found out there is a very thin open area behind the pinbox into the front storage. After removing the screws on the trim behind the pinbox, I pulled the sheeting down and routed the cable to the side of the pinbox and coiled some cable to go to the Tailgater when I set it on the pinbox bracket. Now to run the cable to the rear, add the splitter and connect to the inside cable. Will finally get rid of stringing the cable all over the side of the camper and on the ground.
Thanks B and B.
Well, also just got it run to the back bumper, much easier to run to the back. Just have to anchor the cable and connect to the splitter. Hooray, no more cable laying all over the ground.
mount
