09-12-2018, 07:40 PM
Do you carry an air compressor for your tires?
Hi everyone,
I’m realizing there is sooo much to consider in the RV camping world. (TT world for me) It is very different from the tent camping world I’m coming from. I’ve learned about the mission critical importance of trailer tires, including tire inflation and pressure. It occurred to me I can’t just inflate my tires at the local 7-11 or anywhere like I do with my vehicles. It seems that being self sufficient in tire inflation would be a plus. So do you carry your own air compressors? If not why? What make and model and why? Please excuse me if I missed this thread already.
09-12-2018, 07:46 PM
Yes , always carry. there are some good 12 volt compressors out there that will do the job . i carry a 120v husky 3 gallon ,1 hp oil filled for much of my needs but also have a 12v just in case . one big enough to pump up a trailer tire
09-12-2018, 07:52 PM
Lots of posts on this. Many carry a compressor. Many use a small pancake from whatever their favorite store is. I went with a Viair 400P, mostly due to its small size and overall capacity - it can fill 100+ PSI tires. Good luck
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
I do carry a small 12V air compressor, one that will inflate at least the psi (whatever the RV tire pressure) or more is important. Also grab a 12V Extension cord if you feel the plug in your vehicle may be to far for the power to reach.
I had one that would top out at 40psi, and couldn’t do more if it tried. Had to upgrade for the Trailer use. And it was only about $40.
09-12-2018, 07:59 PM
World Wide Wanderer
Viair. I use a 12 volt that can run off the batteries. Nothing wrong with a 120 volt as long as you have room and access to power.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
09-12-2018, 08:02 PM
Onboard air for us, Pacbrake, love it!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
Yep, I sure do. I gave up using tire pumps a long time ago. You don’t need one of those 80 gallon five-horsepower models though. Any good 12V model will serve well.
09-12-2018, 08:19 PM
I have a twelve volt for tires. Also to blow out water lines for storage.
09-12-2018, 08:31 PM
Casey & Carolyn
I just installed a viair compressor with a 1 1/2 gallon tank. It is rated at 125 psi. I installed an inline air pressure regulator with a 50 ft air hose put a air chuck in the end of the hose that locks on the end the valve stem all tires on the 5 th wheel and truck inflate to 80 psi. I fire up the compressor check all pressures with tpms. Then attach quick coupler to valve stem one tire at a time and let compressor run until compressor quits cycling and move to next tire. Now I’m not holding and air gauge or chuck I’m able to do something else while the air compressor is doing it’s this.
Casey and Carolyn Rice
Las Vegas Nv
2017 Prime Time Crusader Lite 29 RS
2018 Ram 3500 4x4 CC Cummins Powered
09-12-2018, 08:33 PM
Yep, I never head out camping without my VIAIR 90P 12-volt portable compressor.
After I got it, I noticed the cord wasn't very long so I picked up about 20-feet of heavy duty cord at Home Depot and spliced it on. Now, it will reach all trailer tires from a connection to the truck.
Make sure whatever you buy has enough PSI. My Firestone bags don't have a compressor so I use the Viair to get those up to 90 when I'm towing. (40 when I'm not.) I think the big Class-A RVs need 100 psi in their tires.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
09-12-2018, 08:39 PM
I carry a 110 volt pancake air compressor, I have tires that hold 110psi. I carry two Honda’s so electric isn’t a problem. Space isn’t a problem. I normally air up my tires for the season and never add any air to the tires, I have a TPMS on my camper tires and I just look at it often every day
09-12-2018, 08:41 PM
Yep. I carry one that I can hook to my truck battery.
2018 FR NoBO 19.5
2018 F150 XLT, 5.0l ,3.55's
09-12-2018, 08:49 PM
Harbor Freight High Volume 12 VDC compressor here. Not as pricey as Viair and works as well for limited use which I hope will continue to be my frequency of need.
09-12-2018, 08:52 PM
Denver To Yuma In 90 Days
If your trailer tires max out at 65 psi then most of the 12-volt air compressors will work.
If you have 80 psi or higher tires...then most of the 12-volt air compressors won't work.
09-12-2018, 09:00 PM
Location: Alberta - East of the Rockies, West of the Rest
VIAIR 450P
100% duty cycle at 150 psi
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
09-12-2018, 09:07 PM
yes, and have used it. you didn't state what you have. and yes there are many many posts about this.
12 volt dc compressors are nice as you always have 12 volts available. 120 vac compressors need 120 vac power which is not available at the side of the road unless you have a generator with you.
the type of tire you have has an impact. as the psi required in the tire increases the cost of the compressor will go up. don't expect to fill a tire to 110 or 125 psi using a lightweight compressor. many people, myself included, use a viar compressor as we need 110 psi in the tire. they are 12 vdc and do not take as much storage space as the pancake type compressor do.
again research the previous posts and you see thousands of recommendations. and most important, take care of the tires and inflate them properly.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
09-12-2018, 09:20 PM
Originally Posted by rearly7
Same one here, highly recommended
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
09-12-2018, 09:24 PM
Viair mounted in the second battery shelf. Works great.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
09-12-2018, 09:28 PM
I bought my vlair 450 from Jegs for 240.00, I have used it and let friends use it several times, I'm glad I didn't go cheap.
