Old 09-12-2018, 07:40 PM   #1
Do you carry an air compressor for your tires?
Hi everyone,
I’m realizing there is sooo much to consider in the RV camping world. (TT world for me) It is very different from the tent camping world I’m coming from. I’ve learned about the mission critical importance of trailer tires, including tire inflation and pressure. It occurred to me I can’t just inflate my tires at the local 7-11 or anywhere like I do with my vehicles. It seems that being self sufficient in tire inflation would be a plus. So do you carry your own air compressors? If not why? What make and model and why? Please excuse me if I missed this thread already.
Beachbourbon is offline   Reply With Quote
Old 09-12-2018, 07:46 PM   #2
Yes , always carry. there are some good 12 volt compressors out there that will do the job . i carry a 120v husky 3 gallon ,1 hp oil filled for much of my needs but also have a 12v just in case . one big enough to pump up a trailer tire
MR.M is offline   Reply With Quote
Old 09-12-2018, 07:52 PM   #3
rearly7's Avatar
VIAIR 45053 Silver Automatic Portable Compressor Kit (450P-RV), 1 Pack https://www.amazon.com/dp/B0141KJTKQ..._7rBMBbN23M0NN
rearly7 is offline   Reply With Quote
Old 09-12-2018, 07:52 PM   #4
SailorSam20500's Avatar
Lots of posts on this. Many carry a compressor. Many use a small pancake from whatever their favorite store is. I went with a Viair 400P, mostly due to its small size and overall capacity - it can fill 100+ PSI tires. Good luck
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 09-12-2018, 07:52 PM   #5
K2Kevin's Avatar
I do carry a small 12V air compressor, one that will inflate at least the psi (whatever the RV tire pressure) or more is important. Also grab a 12V Extension cord if you feel the plug in your vehicle may be to far for the power to reach.
I had one that would top out at 40psi, and couldnít do more if it tried. Had to upgrade for the Trailer use. And it was only about $40.
K2Kevin is offline   Reply With Quote
Old 09-12-2018, 07:59 PM   #6
World Wide Wanderer
wahoonc's Avatar
Viair. I use a 12 volt that can run off the batteries. Nothing wrong with a 120 volt as long as you have room and access to power.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 09-12-2018, 08:02 PM   #7
Crusadernoob's Avatar
Onboard air for us, Pacbrake, love it!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 2
Crusadernoob is offline   Reply With Quote
Old 09-12-2018, 08:02 PM   #8
Splitshaft's Avatar
Yep, I sure do. I gave up using tire pumps a long time ago. You don’t need one of those 80 gallon five-horsepower models though. Any good 12V model will serve well.
Splitshaft is offline   Reply With Quote
Old 09-12-2018, 08:19 PM   #9
I have a twelve volt for tires. Also to blow out water lines for storage.
tomkatb is offline   Reply With Quote
Old 09-12-2018, 08:31 PM   #10
Casey & Carolyn
Casey r's Avatar
I just installed a viair compressor with a 1 1/2 gallon tank. It is rated at 125 psi. I installed an inline air pressure regulator with a 50 ft air hose put a air chuck in the end of the hose that locks on the end the valve stem all tires on the 5 th wheel and truck inflate to 80 psi. I fire up the compressor check all pressures with tpms. Then attach quick coupler to valve stem one tire at a time and let compressor run until compressor quits cycling and move to next tire. Now Iím not holding and air gauge or chuck Iím able to do something else while the air compressor is doing itís this.
Casey and Carolyn Rice
Las Vegas Nv
2017 Prime Time Crusader Lite 29 RS
2018 Ram 3500 4x4 CC Cummins Powered
Casey r is offline   Reply With Quote
tire, tires
