Old 05-11-2008, 02:13 PM   #1
highwayman's Avatar
Do you guys believe in these??
http://www.forestriveraccessories.com/storeitem.asp?parent=120&parentitem=115508&item=11 5508
highwayman is offline   Reply With Quote
Old 05-11-2008, 03:21 PM   #2
MRimmer's Avatar
I get an error on that link. What is the item?
Mike
MRimmer is offline   Reply With Quote
Old 05-11-2008, 04:15 PM   #3
highwayman's Avatar
SLIDE-OUT SLICKER -
Protects the carpet at both ends of a slide out room as it enters your RV. Just lay it down. •Lift carpet flap on slide room •Lay Slicker down against threshold at end walls •Retract room •After extending room store slicker in closet
Old 05-11-2008, 04:23 PM   #4
MRimmer's Avatar
Lets see if this works?
http://www.forestriveraccessories.co...508&parent=120
Old 05-11-2008, 06:57 PM   #5
Commercial Member
huntr70's Avatar
I have them.............they work great to keep the carpet from wearing, and they also direct any water from the slideout to the outside.
Bought mine from my local dealer though......
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 05-11-2008, 07:14 PM   #6
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Looks like something that would work to me. I don't have them...but I don't move the slide in much. (ok, once so far)
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 05-11-2008, 07:51 PM   #7
Cyber Phrenologist
Radio's Avatar
Hmmm?? Now that brings up a question for me. We ordered ours with "minimum carpet" which means only the bedroom and the slide have carpet. (Kathy likes the beach and wants to be able to just sweep out the sand) I wonder what the impact of the slider would be on the linoleum floor?
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
Radio is offline   Reply With Quote
Old 05-11-2008, 09:30 PM   #8
welshman599's Avatar
Send a message via MSN to welshman599
I'm not sure whether they'd be beneficial or not, especially on cushion floor. Ours slides across carpet and I really can't see any indication of wear or problems but I have considered buying a set for the big slide. Not sure if I will or not really.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 05-11-2008, 10:29 PM   #9
The Jolly Mon
NDJollyMon's Avatar
I'd say be careful with it. I rolled out our fridge (residential style on wheels) to reinstall the ice maker pump and the rollers left an indent in the linoleum. YIKES! Protect what you can...when you can.
Pete (Jolly Mon)
Old 05-12-2008, 11:55 AM   #10
Commercial Member
huntr70's Avatar
The slide slickers have teeth on the bottom also to grip carpet, so if you use them over lino, be prepared for little holes.
Steve and Vicki
2 kids
(Tweaked!!)
