Old 07-07-2012, 09:32 AM   #11
Coops1's Avatar
Have you ever had to pop your ears after opening or closing the slide? The idea sound funny to me
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 07-07-2012, 09:46 AM   #12
lindy's Avatar
Have to open the door to get in the trl to hit the switch to open/close the slide, so I guess YES I do open the door.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 07-08-2012, 10:54 AM   #13
cogito ergo moo
Cowracer's Avatar
1 inch of water column (about .036 psi) is a negligible amount of pressure. While I haven't measured it yet, I deal a lot in my work with flows and pressures, and I'm sure there is more than 1" of water column differential generated when opening my slide with all doors/windows/vents closed. Its not enough to pop your ears, much less cause any damage to seals or windows.
However, lets look at the load on the slide motor. My slide is about 11 by 6 or 66 square feet. That works out to just over 9500 square inches. With even 1" w/c of differential pressure, that is 342 pounds of additional load on your slide motor. Maybe the slide mechanism is designed take it, maybe not. But I think is a good idea to make life as easy as I can on the slide drive system.
I say open vents/doors when running the slide.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is online now   Reply With Quote
Old 07-08-2012, 11:09 AM   #14
CLASS "A" Senior Member
cfsoistman's Avatar
I never gave it much thought but this morning as I closed the main slide (sofa & dinette in one slide) I left the door unlatched. As the slide came in the door pushed open about 6" until the slide stopped, then the door rested back to the jamb. That slide displaces quite a bit of air. Now whether it will cause damage to seals, not sure, but I'll make it a practice to have either a window or the door open when I open or close the slides.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-08-2012, 12:53 PM   #15
prof_fate's Avatar
Almost always - only because the button is in the doorway to the trailer and the we're standing in the doorway when we setup/close up so the door is open.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 07-08-2012, 04:16 PM   #16
DDC
DDC's Avatar
I had a problem with water during heavy rain travel,always on the floor, discovered that traveling with the vents open caused enough negative pressure to over come the lower seals on the slide, if I close the vents no water.(the vents have covers)
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-08-2012, 04:19 PM   #17
Coupey's Avatar
sounds funny, no we dont do that apart from checking through the door to make sure that room isnt getting caught up on anything
Coupey is offline   Reply With Quote
Old 07-08-2012, 04:42 PM   #18
Earth Station's Avatar
I always have the door open. When putting slides out and taking them in. The control panel is set so that I can sit at the door and ope/close/check all switches!! Lets a bit of air in also. Have never been told to or not too! We hit the auto level -- after it is leveled I go and lower the steps and sit there and open the slides in the living area. Then go up to the bedroom and open that one. All the while asking DH if I am clear -- if there are trees even a bit close by. Sometimes -- he prefers that I wait til he is completely hooked up with electric, water and sewer before putting that slide out.
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 07-08-2012, 05:38 PM   #19
Rugged Brown's Avatar
I find chewing gum helps.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 07-08-2012, 06:09 PM   #20
bikendan's Avatar
totally agree! that's a new one on me and one of the strangest claims i've ever seen on any RV forum.
the VW bug was the only vehicle i knew that was that airtight.
i doubt if any RV is that airtight, except Airstream.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
