Old 10-12-2015, 05:48 PM   #1
Komodo's Avatar
Do you turn off the overdrive?
When pulling your camper do you turn off the overdrive?
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. Wolfgang Riebe
Komodo is offline   Reply With Quote
Old 10-12-2015, 05:53 PM   #2
Ford Idaho's Avatar
No.
I like to run in the highest gear possible on cruise control.
Old 10-12-2015, 05:58 PM   #3
Learjet's Avatar
yes and no, I have two overdrives, I lock out one of them 6th.
You'll get all kind of answers, but it really depends on....Gas or Diesel, axle ratio, Transmission, weight of the trailer, flat or hills, headwind or tailwind....
See....its not a simple answer...need much more detail if you want good advice.
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 10-12-2015, 06:00 PM   #4
fmc
fmc's Avatar
I do not use the tow mode most of the time. I do use it if we are in the mountains or another very hilly or steep grade area. I also use cruise control to maintain a constant 62 MPH which seems to give us the best fuel economy.
fmc is offline   Reply With Quote
Old 10-12-2015, 06:02 PM   #5
fonzie's Avatar
Your owners manual should tell you how to use the "overdrive" setting when towing.....
Fonzie
Old 10-12-2015, 06:12 PM   #6
Mr. Dan's Avatar
Originally Posted by Ford Idaho View Post
No.
This is my answer, also. My top two gears are overdrive.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 0; booked = 28
Old 10-12-2015, 06:14 PM   #7
When towing, I turn mine off only when pulling up long steep grades in order to keep the RPM up and the exhaust temp down. I keep the cruise control set on 62-63mph.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 10-12-2015, 06:16 PM   #8
I live in E Tennessee and when driving on highways with not much grade, I always use overdrive. When climbing into hilly or mountainous terrain I use tow mode or drop into the Allison transmission 6 speed. 2006 Chevy 2500HD diesel.
Wumba is offline   Reply With Quote
Old 10-12-2015, 08:20 PM   #9
wingedone's Avatar
The OP's info says a Jeep Liberty. So I agree, what does the Jeep manual say?
You might also try a Jeep forum that has a lot of Liberty users.
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
wingedone is offline   Reply With Quote
Old 10-12-2015, 08:34 PM   #10
Kenny kustom's Avatar
The answer is...
Depends.
If the KJ is always going in and out of od, lock out od.
If it handles od fine, leave it.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
