Old 04-09-2012, 02:59 PM   #11
Barney1's Avatar
Originally Posted by Labzy View Post
Basically, you are comparing active and passive sway control.
Passive sway control helps prevent sway from occuring; while active mainly corrects the sway once it occurs.
Btw....what are the differences between the Laramie and the Big Horn?
That is what I am know realizing (active and passive sway control.)
As for differences between Laramie and the Big Horn - I am not really sure.
I think it is all option packaging.
The technical/mechanical stuff seems all the same.
I do see the "AS SPEC'D CURB WEIGHTS" are different:
Laramie: 5540.00lbs
Big Horn: 5378.00lbs
Laramie has 162 more pounds of options.
Sources:
2011 Ram 1500 4WD Crew Cab 5.6 Ft Box Laramie | Carguide Canada
2011 Ram 1500 4WD Crew Cab 5.6 Ft Box Big Horn | Carguide Canada
Barney
2012 Rockwood Roo 233s
2011 Ram 1500 Big Horn V8 Hemi
Previous Trailer -> 1996 Jayco 1207
Barney1 is offline   Reply With Quote
