09-01-2014, 05:48 PM
Does a TT have to be level ??
I have my Windjammer stored at my sons home. The drive has quite a slope
until I get someone in there with a bobcat it will be that way for a while. The TT is OK from side to side, however the TT is not level from front to back
really no way for a quick fix it without some major grading. Does the TT have to be level for the fridge to operate on propane or shore power ?
Chuck " still in Va "
09-01-2014, 05:58 PM
Gsve the same issue exept mine is not level side to side ive had my fridge plugged in for few days now on shore pwr and it was nice n cold they do say it csn leak ammonia but i didnt have that issue.
09-01-2014, 06:21 PM
You can't add a leveling block, cinder block or 4x4s, under the hitch? Leveling front to back is much easier than side to side.
09-01-2014, 06:37 PM
No its quite an slope, the power jack is almost fully extended which I am not too comfortable with. I have a 2x6 under the jack, unable to get anything else under it while unhitching from my truck, not much clearance. The rear wheels of my f250 were in the street in front of the curb, so the hitch was low. ( to say the least its a tight fit , however the price is right.) I plan on getting a bobcat in there in the upcoming months, my concern is, will it affect the fridge if the tt is not level ? Is it OK to run the fridge to cool it down if the TT is not level .
Chuck "still in Va "
09-01-2014, 06:53 PM
Denver, CO
A non level RV Fridge can form bubbles in places which eventually will prevent the coolant from moving through the system and eventually quit working if it is not level. the coolant depends on natural circulation to move around the circuit and this is impeded if the frig is not pretty level. I think the newer models are somewhat more tolerant than older but the same potential problem exists, as far as I know.
Permanent damage can occur over time, after which an expensive repair (replace the entire cooling element) is needed.
The manuals don't specifically state what "level" is in degrees.
When the rig is moving there is plenty of fluid movement so it is not a problem, only when they are stationary.
Maybe someone here can add some facts or correct this posts if it is wrong.
2017 Fuse 23T
09-01-2014, 07:16 PM
Based on what you have described, I would not run the fridge. "An ounce of prevention is worth a pound of cure."
09-01-2014, 07:29 PM
Jack of All Trades
Frig levelness
What I have always heard and read is 3* front to back and 6* side to side as a maximum out of level for the frig.
Rick
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
09-01-2014, 07:41 PM
I too would not operate the fridge at this point. Just wait until you get to where your going to plug it in or start propane on the road. Might have to wait a day for the grocery shopping at your destination but it is a lot better then blowing a fridge.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
09-01-2014, 08:04 PM
Originally Posted by Jfmf527
We recently purchased a 2004 forest river salem le 28 ft travel trailer as it is out first trailer i was goin over it today and the previous owner told me the hot water heater doesnt wirk on electric as the element burnt out so i was wondering how do i operate it on gas and ive read that before i start it to make sure there is water in the tank, would that b just by filling up fresh water tank? Please help goin on first trip in 2 wks
You need water in the HW tank not just the FW tank. Close your low point drains. Check that your water heater by-pass valves are in the summer use positions. Hook up to your city water input and then run water through your faucets hot and cold. Also open your exterior water heater cover and open the relief valve until water comes out then close the relief valve and cover.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 Chevrolet 4500
Using FR app
on 2012 4500 Chevrolet Chassis
Paul
09-01-2014, 08:16 PM
What are low point drains and where is the shutoff? Also, what is a summer position?
09-02-2014, 08:26 AM
I was responding to Jfmf527's off topic inquiry about using his water heater. His post seems to be gone now. Not sure if it might have been moved. Maybe a moderator can move my response to his question.
Paul
Using FR app
Paul
09-02-2014, 08:33 AM
Bd howie its been moved to itd own thread
09-02-2014, 08:41 AM
Originally Posted by Charles Firth
...Does the TT have to be level for the fridge to operate on propane or shore power ? Chuck " still in Va "
The frig must be level side to side, so, if your frig is on the back wall, you should be ok. IF it is on a side wall, DO NOT USE IT on either propane or 110v.
09-02-2014, 08:45 AM
It really doesn't matter if a refrigerator worked a certain period of time in an out-of-level condition. That's not a good test of whether one can or can't operated a refer out-of-level. Also, it's not about leaking ammonia. See the post by garbonz regarding blockage of the refer's circulation coils.
... and see OldCoot's post about "Don't do it!"
09-02-2014, 09:05 AM
The simple answer is yes it needs to be level or very close to it to run the fridge
Think about things before you do them make life easier not harder.
09-02-2014, 01:31 PM
The TT is still not level, I will be working on that in the coming weeks. I have not tried the fridge in its current state of not being level. I though before I tried the fridge, I needed to ask the seasoned campers. Always good sound advice, info still better than any PDI from any RV super store.
09-28-2014, 05:21 PM
what about when its paked on my propery and not usuing any appliances, electric, water...
09-28-2014, 05:28 PM
It does not need to be level if you are just going to park it.
It is easier to fire things up if you do not have to to hook it up and level it or move it to a more level spot.
I level mine out just so I can check on the inside with the main slide out.
09-28-2014, 05:31 PM
yes u was reffering to just parking it, thsnk u.
09-28-2014, 05:54 PM
Not always. The tongue on a 30 foot plus trailer would need to be 5 or 6 feet in the air to get it level.
I have run a couple of trailers and fridges in my sloped double wide concrete driveway with no issues. And I have no option to level the driveway so I just get the front end up to a reasonable height but not to the point I am afraid of it been so high up on concrete blocks.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
