Old 07-20-2011, 03:59 PM   #1
Iggy's Avatar
Does the truck charge the trailer battery?
I was just wondering when you are ready to tow and your 5th wheel or TT are plugged into your truck will the truck charging circuit charge the trailer battery when driving?
2012 Georgetown XL - 378TS 63K + miles
Old 07-20-2011, 04:03 PM   #2
Yes
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 07-20-2011, 04:04 PM   #3
Jestercyco's Avatar
Yes, the larger white wire at your plug on your truck should be the charging wire for the TT batteries. If it is plugged in to the truck and you are not running the truck it can pull your battery in the truck down. Want to know how I know(been there done that)?
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 07-20-2011, 04:13 PM   #4
KyDan's Avatar
Maybe but probably not much.
The reason is the distance (feet of wire) involved.
The problem is your truck engine battery is very close to the alternator
and it's internal voltage regulator.
The trailer battery(s) is/are several feet down stream.
Your engine battery gets a quick charge and the voltage peaks and the
voltage regulator drops back to a lower voltage.
The trailer battery does not get enough voltage to boost its charge much.
Some folks have run larger battery wire like 8 or even 6 gauge and it seems to help.
There are gismos that you can buy that boost 12v up to a charge voltage
of closer to 15 just for charging batteries while on the road but they're
kinda pricy.
Peace!
Dan & Rita D
Blue Ox WD hitch
2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75
Old 07-20-2011, 04:15 PM   #5
sfrye5853's Avatar
Yes. However, I was told by our dealer that Ford's only work when the key is on. So, if you are connected, but the truck isn't running, there is no drawl.
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 07-20-2011, 04:25 PM   #6
KyDan's Avatar
This discussion comes up here and other RV groups all the time.
Facts
Some trucks have a relay that disconnects the RV battery lead when
the truck is not running.
Some don't.
If you have the relay you probably can't run down your truck battery
by leaving it plugged into your trailer at a camp ground.
MY truck does not have the relay and I have in fact gotten up in the
middle of a cold night and gone outside and plugged my truck back in
so I could get a few more hours out of my LP furnace when my trailer
batteries were dead.
MOST trucks do not have large enough RV battery lead at the plug to
allow much worthwhile charging of the trailer batteries while the
truck is on the road.
YMMV
My last 2 trucks would not charge much.
More than once I've left the camp ground with very low batteries-
driven home (2 hours on the interstate) and once I get home
I turn on lights inside the trailer to unload our gear.
Within a few minutes the lights are dim proving that the trailer
got almost no charge on the drive home.
Just because the engine and trailer batteries are connected via the RV
plug does not mean you will get a meaningful charge while on the road.
The long wire run from engine to trailer produces enough voltage drop
to prevent much of a charge.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-20-2011, 04:31 PM   #7
MtnGuy's Avatar
IMHO, that is a good thing. Theoretically, 12 volt items running in the camper could pull your truck battery down to the point where your truck would not start.
That was more important when I had my Trailmanor, which had a 3-way fridge with a12 volt function. The heating element in that pulled some major amps, so without the Ford 12 volt isolation circuit, that could have gotten me in trouble.
I think some pop-ups still use a 3-way, 12 volt fridge for cooling while traveling, so they need to be aware of that.
Old 07-20-2011, 04:45 PM   #8
Iggy's Avatar
This is what I think my Ford is doing. The truck battery is disconnected when the truck is not running. You see my trailer battery was being used a lot while I was hooked up to my truck and just wondered.
Thanks for the answer.
Old 07-20-2011, 06:07 PM   #9
Terier's Avatar
I was told to unplug it from the truck if I stay hitched at the CG otherwise it could over charge the truck battery.
Old 07-20-2011, 09:06 PM   #10
Iggy's Avatar
Yes this is try if you are plugged into 120 volt shore power.
battery
