Old 07-10-2016, 07:09 PM   #1
Kmsmith's Avatar
Dometic 300 Toilet Replacement Question
So our first 4 or 5 times out all went well. This last trip over the 4th of July the bathroom stunk something awful. It actually even smelled just outside the camper where the tank drain is at when the toilet was flushed. I have since been investigating and found I do have a 300 model toilet and wondered who I need to contact to get it replaced. I'm not sure why the smell was outside the camper also. I came home and flushed the black tank until clear water was coming out of the drain and the next day I stepped in the camper and have since added additional chemicals and left the doors open since it is parked inside. Any insight on how to get my toilet replaced would be greatly appreciated. The camper is a Heritage Glen 263RL.
Thanks, Kent
The Smith's
2016 Wildwood Heritage Glen 263RL
2001 Chevy 3500 Duramax
Kmsmith is offline   Reply With Quote
Old 07-10-2016, 07:17 PM   #2
Wobbles's Avatar
Thanks, Kent
The smell issue can be due to many reasons. Are you using chemicals? You should get a lot of responses here as this is a common subject. I am new to this and will be watching for these responses.
Having said that:
I am going to replace my 300 with an elongated unit for other reasons. I hate having to tuck myself in. I am too big, too old and have a few spendable dollars now.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2015 Grey Wolf 26BH
Wobbles is offline   Reply With Quote
Old 07-10-2016, 07:23 PM   #3
Wobbles's Avatar
I did read that you added chemicals. Just asking if you had been using them prior?
Bob & Michelle
2015 Grey Wolf 26BH
Old 07-10-2016, 07:30 PM   #4
davel1971's Avatar
the smell is likely from your toilet. I had that problem in a 2014 Wildwood. Your dealer should be well aware of the issue with them, and replace it under warranty with an updated model.
David & Lynn
Old 07-10-2016, 07:38 PM   #5
Kmsmith's Avatar
Yes we always you chemicals. Actually as soon as i empty it i add some water and chemical immediately.
Old 07-10-2016, 07:39 PM   #6
Kmsmith's Avatar
Thanks, I did not know if i had to take it to the dealer or if Dometic would send one and just replace it myself...
The Smith's
Old 07-10-2016, 07:42 PM   #7
davel1971's Avatar
wouldn't hurt to try that route first. Would be my preference too. They are easy to replace, and I don't want mine at the dealer unless absolutely necessary.
David & Lynn
Old 07-10-2016, 07:46 PM   #8
Wobbles's Avatar
You can search YouTube. I have found numerous videos showing the the effort.
Looks simple to me.
Bob & Michelle
2015 Grey Wolf 26BH
Old 07-10-2016, 08:02 PM   #9
Kmsmith's Avatar
Yes it should be the same as a house toilet. Disconnect the water lines, undo the (2 )7/16 nuts at the base, lift off and replace. Its definitly under warranty but just trying to avoid having to be in the shop if they would send to me. Guess I can just contact Dometic tomorrow.
Old 07-10-2016, 08:15 PM   #10
I had same problem. Called Dometic and they sent a new updated toilet to my house. easy job just DO NOT TILT the toilet when removing form RV the liquid between the upper and lower half will spill on the floor. That is where the smell is from, the open area on the back side.
drc343 is offline   Reply With Quote
dometic, replacement
