Old 01-05-2016, 03:21 PM   #1
Bill Scott
Dometic 3313192.xxx thermostat off 20 degrees
Had this 2015 HR Salem Hemisphere RV for about a month. The first trip the thermostat was working fine, except I had to set the fan to auto. But the last day of the trip, with the temp set at 70 degrees the furnace wouldn't come on. Thinking I was out of propane, I switched the bottles and still the furnace would not come one. When I set the thermostat to 90 degrees, it finally came on and heated the trailer up to 69 degrees and then shut down. Through trial an error, I discovered that by setting it to 80 degrees it would turn off at 60 degrees. Dometic said, take it in for service. I am going to try the reset function first. But before I do, I though I would pass this question along to the forum and see if anyone has had a similar experience.
BillScott is offline   Reply With Quote
Old 01-05-2016, 03:35 PM   #2
Flybob's Avatar
Try this .
A system initialization will need to be performed by the installer after
the system is installed.
• Make sure the Single Zone LCD thermostat is in the Off condition.
See page 4, “Quick Reference To Control Buttons”.
• Press the “+” button and, while holding it, also press and hold
the On/Off Mode button for three seconds. LCD will show
― ― . Press the On/Off Mode button again to turn system off.
This completes the initialization
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-05-2016, 04:59 PM   #3
Bill Scott
Tried that flybob, It appears to be only 10 degrees off now. Looks like resetting to factory specs doesn't do it.
Old 01-05-2016, 05:02 PM   #4
mjones12's Avatar
Good info. Any reason not to do this if the T-stat just seems to be 5 or 6 degrees off?
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 01-06-2016, 08:16 AM   #5
Bill Scott
Last night, I set the thermostat to 60 degrees. This morning the temp outside is 37, and it's 42 degrees inside the coach. I turned the thermostat off, then back on, and the furnace started running. My guess is it will shut down in a few minutes. The thermostat is selling n Amazon for $23. It's under warranty of course, but I am wondering if I buy the new thermostat and replace it, if it will solve the problem. Or based on the symptoms, could it possibly be the furnace that's a fault?
Old 01-06-2016, 10:32 AM   #6
Head Rambler
It's probably the T-stat, but with these electronic units it could be the control board inside the A/C unit.
If it's not a huge pain, I'd suggest taking it to the dealer.
A new head unit and control kit is about $90.
Gotta go campin!
Old 01-06-2016, 07:57 PM   #7
Send a message via Yahoo to carluv
FlyBob, my T stat is about 10-12 degrees off. The page 4 you mention, is that in a Dometic book somewhere?
carluv is offline   Reply With Quote
Old 01-09-2016, 09:51 AM   #8
Bill Scott
**UPDATE**
After a 250 mile pull, the furnace works again. I think I need to search for a loose wire or a cold solder joint,
Old 01-09-2016, 10:11 AM   #9
Flybob's Avatar
Yes see attached
TST Tire Monitors
2 100W solar panels
dometic, thermostat
