Originally Posted by tdazbell
Resetting the thermostat did not have any effect. It does not appear to be froze up. I have not found the sensor connection yet but that may be the issue. I noticed today while my wife was doing the laundry and the washer went into the spin cycle the AC started working just fine for a while and then quit. The next time the washer went to spin cycle I was watching and the inside temp reading jumped from 32 degrees to 84 degrees and the AC worked. Now all I have to do is to talk my wife into doing more laundry.
Can't be sure about yours as our RV is an entirely different model (we have a Legacy), but we have the same thermostat. In the bedroom, the sensor is up on the wall by the bathroom door and looks sort of like the microphone that's built into your car for the phone; just a small circle with some very small holes in it. From what you said about it working when your wife runs the washer, I would try to look for the front sensor on one of the walls around the washer/dryer and see if there is a wire that is loose and making contact when it gets shaken by the washer. Just a guess, but that's what I would look for. Good luck.
