Old 06-02-2016, 07:13 PM   #1
justpassinthru's Avatar
Question Dometic Fridge Questions
Hi Friends i was reading todays forum and i see a question regarding adjustments for temperature for fridge, by sliding the white plastic piece atrached to the fins inside fridge. But my 2015 Wildwood 28RLDS (28 FT REAR LIVING DINING SLIDE ). Doesnt have a such white slide adjustment on the fins Is mine missing or is mine have a different temp adjustment? I did notice that previous weekend out for 4 days couldn't get temp below 40 degrees. I also have a battery powered portable fridge fan made to circulate the air within fridge. Any help appreciated. Thanks Jim
justpassinthru is offline   Reply With Quote
Old 06-02-2016, 07:18 PM   #2
What is the model number on the fridge that will tell you a lot.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 06-03-2016, 07:48 PM   #3
dometic fridge.
Thanks for reply just got off phone with dealer going to try this coming weekend to raise white fin lever higher and see how that work. Thanks again Jim
Old 06-03-2016, 07:52 PM   #4
dcheatwood's Avatar
So you do have a fin mounted thermistor?
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
dometic, fridge
