Old 06-28-2015, 06:40 PM   #1
TnVol's Avatar
Dometic refrg pilot light won't stay lit
Testing systems out on our new camper and the fridge works great on AC power but on gas, the pilot light keeps going out. I tried to purge the air from the gas line by lighting one of the stove burners for a minute or two.
It's a 2005 Rockwood 2601 Ultralite with DSI on the fridge and HWH, and the propane tank is full as of last week. Other one has some gas, but I have it switched to the full tank. Stove, outdoor bbq, etc. works fine. Also keeps kicking off the gas leak detector, though I can't smell ANY propane, inside or out. I'm thinking its something simple that probably needs adjusted or cleaned out. Anything in particular to look for?
Thanks.
TnVol is offline   Reply With Quote
Old 06-28-2015, 06:49 PM   #2
If it is DSI, there is no pilot light. It automatically lights the burner, which stays lit until the frig is cooled and then shuts off.
Old 06-28-2015, 06:59 PM   #3
TnVol's Avatar
That's a bit of a relief. Problem is the check light keeps coming on. I hit the power button and start it again, and it works a little while then the same thing. Put a thermometer in it and it was about 50. I ran it on AC for several hours before testing, so the fridge was cold.
Old 06-29-2015, 06:21 AM   #4
fonzie's Avatar
How's your battery voltage, needs 12 volts and more......
Fonzie
Old 06-29-2015, 06:26 AM   #5
Herk7769's Avatar
Flame lights but does not stay lit?
Did I get that right?
Or does it spark but not light?
HAM CALLSIGN - KC3FFW
Old 06-29-2015, 07:20 AM   #6
TnVol's Avatar
Yes, it lights but doesn't stay lit. Battery is fully charged according to monitor (with shore power unplugged).
Tom, Joyce, Faith & Ben
99 GMC Sierra SLE 5.3
Old 06-29-2015, 07:37 AM   #7
Herk7769's Avatar
If it lights the battery is fine.
Does not stay lit could be gas pressure: check that you can light all 3 burners on your stove at the same time. (I will assume that is good as well).
The next to checks involve some disassembly; so remove the metal wind shield and look at the arrangement of the parts.
While you have your cover off the flue pipe, make sure the overheat sensor is pressed in (not popped). Test to make sure it has continuity.
Next your flue could be clogged with a wasp nest. This is a bit harder to clean without some disassembly. Get access to the bottom of the flue and blow it out with compressed air. The flue gasses of combustion could be preventing fresh combustion gas from keeping the flame lit.
You may need to remove the gas solenoid and pull it back a bit to get your air nozzle in there.
If all these are good, the flame sensor part of the control board could be bad. It uses the ionized gas of the flame, the ignitor itself and the frame of the fridge to detect a low current flow. A board replacement is the only way to fix this.
Name:	Camper Fridge 001.jpg
ID:	81571   Click image for larger version
Name:	Camper Fridge 004.jpg
ID:	81572   Click image for larger version
Name:	Camper Fridge 002.jpg
ID:	81573   Click image for larger version
Old 06-29-2015, 08:10 AM   #8
TnVol's Avatar
Thanks Herk, good info. I'll be checking on it this evening.
Old 06-29-2015, 09:19 AM   #9
I Break Everything
mikel68's Avatar
Check for dirt dawber/wasps next up the exhaust. Do these things have thermocouples? It's a heat sensor that goes back to the gas valve. If it's broken it will let you light it, but will go out.
2015 Georgetown Forest River 351DS MH
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
Old 06-29-2015, 09:24 AM   #10
Herk7769's Avatar
They use a flame sensor using the flame itself to detect ignition and keep the valve open as long as it is burning.
dometic, light
