Old 07-05-2016, 10:56 PM   #1
Nola tink's Avatar
Dometic refrigerator not cooling
We have a tracer 230 fbs with a dometic refrigerator. It is our first time using it. The outside fridge is cool and the upper freezer part of the inside refrigerator is cool but the bigger bottom part is warm. It was working fine when we bought it about 3 weeks ago. Any suggestions?
Nola tink is offline   Reply With Quote
Old 07-06-2016, 12:29 AM   #2
check to see if the white slide on the fins is all the way up. This controls the fridge temperature.
AbdRahim is offline   Reply With Quote
Old 07-06-2016, 08:25 AM   #3
Mr. Dan's Avatar
... and not just the slide but the thermistor inside the slide. I've had our slide all the way to the top only to find the thermistor had slipped down inside the slide.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 00; booked = 14
Old 07-06-2016, 01:58 PM   #4
Nola tink's Avatar
Thanks for the help! I also learned that it just takes a l-o-n-g time to get cool. When I checked it this morning after it being on all night it was cool! Didn't realize there is a thermostat inside the slide. I will check for that.
Old 07-06-2016, 02:04 PM   #5
Flybob's Avatar
Fridges work by removing heat energy. When a fridge is empty, there is little mass inside to absorb heat energy let in by opening so temp will change rapidly. When starting a fridge before a trip, Start 12hrs or more before, Fill the fridge with cold non perishable items ( water, drinks etc). They will provide cold mass to absorb heat when opened. You need some space for air to circulate, but a full fridge or freezer will always work better than an empty one,
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-06-2016, 02:35 PM   #6
D_B Travelers's Avatar
Yup, ours didn't cool all that well on one trip and then on the next trip it froze everything in the refrigerator. The thermistor was completely out of the slide and had fallen back behind the crispers. I put a small dab of silicone on the thermistor to keep it in place on the slide, it doesn't budge now.
D_B Travelers - 35 nights in 2016... so far. 54 nights in 2015. 2014 Rockwood Windjammer 3001W Diamond Pkg, 2015 GMC 3500HD CC DRW Duramax, Equalizer 14K hitch, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 07-07-2016, 09:16 AM   #7
Nola tink's Avatar
Thank you Flybob! Valuable knowledge for the future!
Old 07-07-2016, 01:53 PM   #8
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
I bought a couple of those little battery operated fans for the freezer and fridge. Does a good job of distributing the cold in both chambers real well. Worth the investment. Two D cells for each fan and they usually last a month. Keeps my ice cream hard.....that's all that counts.
Grampa Jim is offline   Reply With Quote
Old 07-07-2016, 02:27 PM   #9
I added one of these fans to my fridge.works great
Dometic Refrig Fan w on Off Switch Increases Cooling Standard Model | eBay
Mark1 is offline   Reply With Quote
Old 07-07-2016, 02:31 PM   #10
dmchapman's Avatar
I have noticed the thermistor is loose in the slide clip. A dab of silocone would fix that but what is the correct position of the capsule inside the slide?
dmchapman is offline   Reply With Quote
cooling, dometic, refrigerator
