Old 06-26-2016, 03:26 PM   #1
Dometic thermostat
We have a 2015 Tracer Ultra Lite. The thermostat keeps on beeping. It's driving us crazy. How can we stop this? Any help is appreciated
Hanger8 is offline   Reply With Quote
Old 06-26-2016, 03:28 PM   #2
Dometic thermostat
How can we stop thermostat from beeping?
Old 06-26-2016, 03:43 PM   #3
Are you sure it is the thermostat and not propane/co detector? Mine is mounted on floor under thermostat...
Old 06-26-2016, 03:46 PM   #4
We actually removed that. That's what we thought. We were camping and needed to stop it. It's the thermostat. The dogs were going crazy
Old 06-26-2016, 04:11 PM   #5
What thermostat do you have?
Old 06-26-2016, 04:13 PM   #6
Dometic
Old 06-26-2016, 04:17 PM   #7
Dometic
I guess I meant what model of Dometic do you have? Also, I have to ask if you checked smoke alarm on ceiling...
Old 06-26-2016, 04:18 PM   #8
Also, when you removed co alarm did you take it outside or away from unit? They have rechargeable batteries and will beep when low. Disconnecting just removes it from charging power, still has battery inside.
Old 06-26-2016, 04:22 PM   #9
Wow, thank you. These are both good ideas. We're new to this, as you can tell. I'll go to the campsite and check these. We ( and the dogs) are very grateful.
Old 06-27-2016, 04:31 PM   #10
I really want to thank you. It was the battery in the smoke detector. I admit I feel kind of dumb. I never even thought to look there. Thanks again
Old 06-28-2016, 10:08 AM   #11
Thank you for coming back and letting us know what you found. Sometimes the simplest things trip us up. Glad it was an easy fix.
Gotta go campin!
dometic, thermostat
