Old 10-02-2018, 08:18 PM   #11
Originally Posted by markb422 View Post
For a little more $ you can get the 320 with the spray wand.
The sprayer is very useful.
2017 Riverstone 38FB Legacy
2018 F450
LegacyFB38 is offline   Reply With Quote
Old 10-03-2018, 08:24 AM   #12
pokey's Avatar
The landfills must be full of 300's.
I'll check that out, thanks.
Pokey
Permanent RV'er
2006 Cardinal 29LE
Why do today what you can put off until tomorrow.
Retirement life........
pokey is offline   Reply With Quote
Old 10-17-2018, 03:51 AM   #13
pokey's Avatar
Originally Posted by pokey View Post
I need to replace the seal on the toilet in my 2003 Forest River Cardinal Fifth Wheel and do not see the model number anywhere? Does anyone know where it may be located? I used Thetford toilet cleaner / conditioner recently and worked fine until now. Thanks all
To help others that may or may not need to toilet seal replaced. I did order the seal to replace mine that was allowing water to seep trough. Reading the very easy to install directions the last step was to apply petroleum jelly or a silicone gel to the bottom of the gasket to assure a good seal. I decided to just apply petroleum jelly to the bottom of the bad one and it works great with no leakage period. If and when it starts leaking again I'll replace it with the new one but for now it works just fine.
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 10-24-2018, 03:25 AM   #14
pokey's Avatar
Update that may help others with a toilet seal issue. I ordered a seal for the Dometic/Sea land toilet model # 320. Mine turns out the be a 210 series installed in older RV's. On the 210's the flush lever is on the left of toilet, the 300, 310 and 320 series the flush lever is on the right. The label showing the model # etc. on the 110, 210 and 510H series is located in the front by easily pulling out the lower front cover, the newer models have the info on the rear of the toilet.
Pokey
Permanent RV'er
2006 Cardinal 29LE
dometic
