Old 10-02-2018, 08:09 AM   #1
pokey's Avatar
Dometic Toilet Model Number
I need to replace the seal on the toilet in my 2003 Forest River Cardinal Fifth Wheel and do not see the model number anywhere? Does anyone know where it may be located? I used Thetford toilet cleaner / conditioner recently and worked fine until now. Thanks all
Pokey
Permanent RV'er
2006 Cardinal 29LE
Why do today what you can put off until tomorrow.
Retirement life........
pokey is offline   Reply With Quote
Old 10-02-2018, 08:22 AM   #2
Flybob's Avatar
Unless the seal is damaged or missing, it can usually be removed, lubricated and replaced (with gloves). The model number is inside under the toilet. Most common are model 300 (plastic) or 310(ceramic).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-02-2018, 08:26 AM   #3
It's usually down near the floor, behind the bowl. If you have a phone with a camera, you might be able to get your arm back there and take a pic of it.
Iwritecode is online now   Reply With Quote
Old 10-02-2018, 08:29 AM   #4
I have a Dometic 300 toilet in my TT. The toilet info is on a tag on the right hand side of the base (as you look at it).
It was hard to see so I just slid my cell phone in the space and took pictures until one came out good.
2018 Forest River Flagstaff E-PRO 19FBS
2107 Toyota Highlander
NC_RVer is offline   Reply With Quote
Old 10-02-2018, 08:35 AM   #5
pokey's Avatar
Thanks all for the information. I looked with the light on my phone and didn't see it. The lable should be there as shown above so I'll look again. Thanks for the replies.
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 10-02-2018, 08:46 AM   #6
pokey's Avatar
Thanks for the model numbers. I just looked again taking pictures with my phone and didn't see it anywhere. I'll order the 310 and that should take care of it. Thanks again.
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 10-02-2018, 10:45 AM   #7
I just watched a video on how to install a model 310. (It was a refresher as I’m planning on installing a 320.) I saw that the info tag was on the backside of the toilet.
Old 10-02-2018, 10:57 AM   #8
pokey's Avatar
I looked twice and took pics of the back and didn't see it at all. I ordered the 310 from Amazon and also watched videos on YouTube. It seems pretty easy. Thanks for the info.
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 10-02-2018, 12:45 PM   #9
Just as confused as you
Scrapper's Avatar
The tag on my 310 is under the back of the toilet facing the floor, you need a mirror or use the front camera of your phone to see it.
Richard & Jill
Camping since 1989, seasonal since 2000
Car Shredder Operator/Technician, Scrap Metal Recycling - retired
Old 10-02-2018, 05:41 PM   #10
For a little more $ you can get the 320 with the spray wand.
The landfills must be full of 300's.
markb422 is offline   Reply With Quote
dometic
