Old 04-26-2016, 02:40 PM   #31
Pickin' & Campin'
Murphy Oil Soap is a cleaning product marketed by Colgate-Palmolive. It was originally invented by Murphy-Phoenix Company, later became Colgate-Palmolive's subsidiary in 1991.[1] It is available in a concentrated liquid form which is then mixed with water, as well as pre-diluted form which comes in a trigger spray bottle. Commercials for the product state that the product is ideal for cleaning wood surfaces.
Murphy oil soap does not contain petroleum-based oil; it contains potassium soap manufactured from vegetable oil. The other constituents of Murphy Oil Soap are sodium EDTA, propylene glycol, fragrance, surfactants, and water.[2]
Murphy Oil Soap is commonly used to clean and polish horse tack, such as bridles and saddles. It is also commonly used to clean black-powder weapons after use, since the lack of petroleum-based oil and the presence of vegetable oil lessens the amount of sludge that is created when cleaning black powder residues from weapons. It has also been found to efficiently remove the black powder residue that builds up on automobile wheels and hubcaps from the disc brakes. Murphy Oil Soap is also an excellent lubricant to use with water when throwing clay on a potter's wheel[citation needed]. It has also been found to quickly and easily dissolve water-based inks, such as Crayola marker ink, from acid-free paper.[3]
Diluted Murphy Oil Soap (2-4%) is often used by home gardeners as an insecticidal soap spray.
Cool... made with RV antifreeze!
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-26-2016, 03:06 PM   #32
Great replies.
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
larryo is offline   Reply With Quote
Old 04-26-2016, 04:03 PM   #33
Originally Posted by larryo View Post
I'll try this again. Do you or would you use Dove dish detergent to clean the roof of your camper. Yes or no?
Use dawn to clean, rinse and use Aero 303 it is real good for uv protection. But I clean mine at least 3 times a year.
Myrle is offline   Reply With Quote
Old 04-26-2016, 04:26 PM   #34
Somewhat right of center
Crabbyguy's Avatar
Hmm. I've been using Simple Green. So far so good.
2014 Crusader 260RLD Champagne Touring Edition
2013 Silverado 2500 6.0 HD
Crabbyguy is offline   Reply With Quote
Old 04-26-2016, 04:53 PM   #35
MacDR's Avatar
First you need to find the roof
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Richard Bong Recreation Area
June 2-5 site 225
2014 Columbus 340RK
Day's Camped 2018 "14"
You can find us: Egg Harbor Campground 7/9 - 7/11
MacDR is offline   Reply With Quote
Old 04-26-2016, 05:03 PM   #36
ramair's Avatar
Use dawn dish soap to clean ours.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 04-27-2016, 08:29 AM   #37
Wolverine 1945's Avatar
Back about 10 - 12 years ago we bought a Flagstaff TT with a rubber roof,,, the paperwork that came with TT said to use a Natural Soap to clean the roof ???
Murphy's Oil Soap is the only Natural soap I know of !!! That is all I ever used !!!
Wolverine 1945 is offline   Reply With Quote
Old 04-27-2016, 08:31 AM   #38
Pickin' & Campin'
Rubber roofs (EDPM) are a different animal than the newer TPO roofs.
Old 04-27-2016, 08:52 AM   #39
I see that !!! But I would probably still use Murphy's,,, just to be safe !!!
Or what ever the TPO manufacture recommended !!!
Remembering that what ever you use,,, will be running down the sides of your unit !!!
Old 04-27-2016, 11:41 AM   #40
Pickin' & Campin'
As was mentioned... the TPO manufacturer recommends Dawn.
roo, roof
