Old 09-24-2012, 01:11 PM   #1
Draining fresh water
My fresh water tank is 1/3 filled and I like to drain it for camp this weekend. I tried the low point drain but no water is coming off from the cold valve (cold valve only drains when city water line is turned on).
Any idea what my other options are besides turning on the pump and use the water?
It is a Thor Wave 22RB year 2006.
Thanks,
tntrac
tntrac is offline   Reply With Quote
Old 09-24-2012, 01:16 PM   #2
Thanks,
tntrac
Your trailer should have a drain valve directly connected to the fresh water tank. Hunt around under the trailer in the vicinity of the tank (if you can locate it) - it might be quite inconspicuous .
...VTX-Al
VTX Al is offline   Reply With Quote
Old 09-24-2012, 01:35 PM   #3
...VTX-Al
I double check tonight. With this brand of trailer, they have a black plastic covering the underside.
Old 09-24-2012, 01:37 PM   #4
TURBS's Avatar
As most do.
I thought I had a pic on my phone of mine but I don't.
Turbs
Old 09-24-2012, 03:20 PM   #5
Look directly below the fill under the trailer.
ID:	19861   Click image for larger version
ID:	19862   Click image for larger version
Old 09-26-2012, 06:57 AM   #6
Thanks,
tntrac
Mine has a hose that is connected to the tank. It has a cap that can be removed to drain the tank. You have to crawl under the trailer to find it. Good luck!
Top B is offline   Reply With Quote
Old 09-26-2012, 11:51 AM   #7
I found the plastic nut . I am thinking of replacing it with a valve. Any cons if I do this?
Old 09-26-2012, 12:16 PM   #8
i routed mine with pipe and a valve closer to side. this way i didn't have to crawl underneath like it was originally configured.
gtmustang65 is offline   Reply With Quote
Old 09-26-2012, 12:26 PM   #9
Pros: You don't have to crawl under the TT and it will be quicker.
Cons: It only has to leak 1 time to ruin a trip.
