Old 04-20-2011, 11:11 AM   #11
Bear's Avatar
If and when you do decide to get new batteries, I would go with the 6 volts. The camping we do is much different than yours, we dry camp about 70 days a year. I have run my Trojan T105 6 volts for 8 years through 2 different trailers and they are now getting to the point where I have to change them. I do have 3 100 watt solar panals keeping the 6 battries charged, as well as an inverter/charger that will start the genset if the battry power gets to low, it has only started the gense once about 4 years ago, we had been dry camping and it was overcast and rain for 11 days, it was cold enough to run both furnaces at night and we did watch the TV (36" plasma) 3 or 4 hrs a night (because it was raining) on the 10th night, power finally dropped below 11.2 volts in the battries and it started the genset. These battries have amasing capacity, I need new ones this year and I am buying new 6 volt Trojan T105's.
2000 Volvo 660 D12 425 hp 1550 torque 15 speed, Trailer Saver air ride hitch. 2006 Canadian Sport 385 RLTS 40'10" triple slide, triple axle 5'er toybox, 300 watts solar, 3000 watt inverter, Onan 5500 Marques Platnum. 1998 Polaris 300 Explorer 4X4 quad, 2003 Polaris 700 Sportsman 4X4 quad, 1994 Jeep YJ "TOAD" 3" lift 31" ProComp Mud Terrain tires
http://community.webshots.com/user/Bears319
http://www.picturetrail.com/bears319
Mission Statement : ZZZZzzzzz
Bear is offline   Reply With Quote
Old 04-20-2011, 12:13 PM   #12
I camp 2 or 3 times a year dry as well, and I just added a second Interstate 12v deep cycle to mine, and I use one until it starts to die, then switch the wires to the other for the remainder of the trip. I also do have a 3500 watt generator, but seldom ever need it. Randy
Old 04-21-2011, 03:22 PM   #13
Thanks for this. It begs the question, though: is it better to have the batteries connected with leads, in the case of the 12v deepcycle battery positive to positive and negative to negative, or is it better to run one battery until low, then switch the wires to the fresh battery? And what gauge connector wire is appropriate for 12v dc batteries?
Logically, I assume that wiring in series would be advantageous since both batteries will charge at the same time and rate. Then again, you know what happens when one assumes.....
Gkconfer is offline   Reply With Quote
Old 04-21-2011, 03:33 PM   #14
MtnGuy's Avatar
You do not want to wire 2 12 volt batteries in series....that would give you 24 volts.
You need to wire the 2 12 volt batteries positive to positive, negative to negative. Ideally, the positive to the trailer would come off of 1 battery, and the negative to the trailer comes off of the 2nd battery.
Old 04-21-2011, 03:42 PM   #15
Thanks Mtnguy and good catch. I should have said parallel and not series...big difference. I also found the answer to one question regarding proper wire gauge. For the 12v dc, it looks as though 2 gauge is the right choice for a 12" to 18" wire.
Old 04-21-2011, 03:45 PM   #16
Mtnguy, any chance that a picture of this wiring setup can be found on the site? I looked but didn't find one. Thanks
Old 04-21-2011, 04:31 PM   #17
Herk7769's Avatar
Here you go
The first is two 6 volt in series. The second is 2 12's in parallel.
NOTE: In the 12 volt example, the Ground is NOT on the same battery as the Positive. That keeps current flow through both batteries equal, assuming both batteries are of the same age and recharge status.
HAM CALLSIGN - KC3FFW
Old 04-21-2011, 04:58 PM   #18
Herk7769's Avatar
Just curious, don't you have room to put both in the system or is there another reason you lug around a second battery not put it in the circuit permanently?
Old 04-21-2011, 05:27 PM   #19
Another option for having two 12v batteries, as I do, is to use a battery switch. I picked one up fairly cheaply and mounted it to the TT frame right behind the two batteries on the tongue. With this switch, you hook both batteries to the switch, along with connections to the TT, and then can select battery 1, battery 2, both, or neither (off). Serves the same purpose as 08flagvlite, but also allows you to easily disconnect the batteries so they don't discharge when not in use.
LoryJ is offline   Reply With Quote
Old 04-21-2011, 05:33 PM   #20
Herk7769's Avatar
This is exactly how my 5th wheel battery bank is set up.
