Old 05-22-2018, 12:47 PM   #1
Dual zone thermostat question
I have the Rvcomfort.zc thermostat in our 2018 Flagstaff Super Lite 29 KSWS and can't t find an answer to my question in the instructions. Tried a search on forum but struck out also. I am wondering if I can run the second air conditioner ( in bedroom ) by itself ? At a 30 amp pedestal right now, so can only run one air at a time. Thought I would switch between units and use the bedroom unit in the daytime to reduce noise in living area. But thermostat doesn't seem to want to turn it on by itself. Ran into this over the weekend, so trying to figure it out. Thanks for any help.
tonyz1 is offline   Reply With Quote
Old 05-22-2018, 01:36 PM   #2
ben31's Avatar
http://www.rvtechlibrary.com/heatair...at_install.pdf
It appears you can with those. I looked up two models and they both say you can. Check this out, as it looks like all of the zc models work about the same way.
Good luck!
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 05-22-2018, 04:26 PM   #3
Thanks ben31, I'll check it out again. The living area unit is zone 1 and bedroom is zone 2. I could go to zone 1 and go thru options to get air to come on. There is no slide switch on mine just buttons. Anyway, when I went to zone 2, it would let me toggle thru the heat and cool systems but wouldn't give the cool on option. Didn't mess with it much then but I'll get more into it when I'm at the camper next. Probably me either fat- fingering something or being impatient and not waiting for display to change states. Thanks again, I'll post when I figure it out.
Old 05-22-2018, 04:29 PM   #4
I should have added that after I turned cool off in zone 1 it wouldn't give the cool on option in zone 2.
Old 05-22-2018, 07:52 PM   #5
Rookiewood's Avatar
Yes you can !
2016 Chevrolet Silverado 2500HD LTZ Z92
Rookiewood is offline   Reply With Quote
Old 05-22-2018, 09:10 PM   #6
Thanks, I'll try it again when I'm back at the camper in a couple days. Maybe I was missing a step or something, probably OE!
Old 05-23-2018, 03:00 PM   #7
If you can't turn Zone 1 off... how about just running the temperature up real high so it will not come on... and set Zone 2 to the temperature you want in the bedroom.
PapaE is offline   Reply With Quote
Old 05-23-2018, 04:50 PM   #8
Thanks PapaE, that might just work. Turn both zones on and turn whatever zone I don't want to run way up. I can switch temps between units day or night. If nothing else works, I'll try it out. Thanks again.
Old 05-23-2018, 05:14 PM   #9
I have a Rockwood (Flagstaff twin) with dual zone thermostat, front and rear air conditioners both ducted. When watching TV I run the bedroom air (zone 2) because it is quieter in the living/kitchen area. When sleeping I run the kitchen/living air (zone 1) because that doesn't wake me when the air cycles. If it's really hot I run both, but that takes 50 amps.
Each zone can be turned off or on independently of the other
I'm not totally useless, I can be used as a bad example.
RFSims is offline   Reply With Quote
Old 05-23-2018, 05:53 PM   #10
Thermostats
I have a coachman 5ver with Coleman air and dual thermostat you need to program thermostat for each zone for equipment on each zone ie zone 1 gas furnace, and air conditioner zone2 air conditioner ect
royg6677 is offline   Reply With Quote
thermostat
