Old 03-27-2014, 09:14 AM   #1
jonrjen's Avatar
Ducted A/C vent removal question.
2013 Wildcat 5th wheel, has ducted a/c that runs from the rear of the trailer towards the front.
My question is, is there any secret to removing the directional vent that mounted in the ceiling. Do you simply pull, twist, pry, wrangle or ?
2018 Berkshire XL 40B
Past RVs: National Pacifica 40', Kenworth T300 Toterhome, Jayco Class C 32'. American Eagle 40',
American Eagle 40', Bounder 38' tag axle
jonrjen is offline   Reply With Quote
Old 03-27-2014, 09:28 AM   #2
TURBS's Avatar
Yes all of the above.
"Twist" "pry" "wrangle" "squeeze"
"Poke" "wiggle"
TURBS
Sabre owners united!
Old 03-27-2014, 09:44 AM   #3
jonrjen's Avatar
Darn, I was in hope of an insider industry secret. Guess I could place one of the grandkids on a ladder up near the vent and say "don't touch that". I'm sure he could get it out very fast.
Old 03-27-2014, 09:58 AM   #4
TURBS's Avatar
Lol!
I had a tough time the first one I took off to.
After that I just reached up and grabbed it and gave it a "quick" pull.
They just snap into place.
TURBS
Old 03-27-2014, 10:15 AM   #5
jonrjen's Avatar
Thanks for the assist, I go give it a jerk and see what happens.
Old 03-27-2014, 10:18 AM   #6
TURBS's Avatar
Please don't involve "old coot" re: "jerk" he'll just over analyze it and it'll be a three hour deal it'll break then he'll blame me.
Good luck.
Btw why are you removing it?
TURBS
Old 03-27-2014, 10:38 AM   #7
jonrjen's Avatar
Good luck.
TURBS
I was talking about the "jerk" as a verb, not as a proper noun......LOL!!!
I want to make sure that the a/c duct runs are closed off at the ends of the run on each end. Many RV manufacture leave them open which allows for the conditioned air to be dumped into the front and rear caps or the ceiling void. I was also going to experiment with blocking the vent closed on the lower level as we have a 2nd non ducted a/c unit in the bedroom and forward full master bath.
Old 03-27-2014, 10:43 AM   #8
Oakman's Avatar
I'm curious, why do you want to do that?
Sent from my NX008HD8G using Forest River Forums mobile app
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-27-2014, 10:52 AM   #9
jonrjen's Avatar
I was also going to experiment with blocking the a/c duct closed on the lower level as we have a 2nd non ducted a/c unit in the bedroom and forward full master bath. As it is now the vents in the bedroom are mounted so near the 2nd roof a/c unit that it blows on the unit, cools it down and caused it to cycle when it shouldn't.
So I was going to experiment with blocking the duct air from going past the lower level of the 5th wheel and allowing the 2nd unite to cool the upper level (master bedroom and forward master bath). Or experiment with simply closing off the two ducted vents in the master bedroom and allowing the duct air to go forward to the master bath.
All has to do with hvac management flow/control.
Old 03-27-2014, 11:07 AM   #10
BigTJohn's Avatar
An aluminum bicycle tire lever works great and you have to "jerk" (aka OC it) to remove.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 03-27-2014, 11:19 AM   #11
TURBS's Avatar
Originally Posted by BigTJohn View Post
Attachment 48562
Attachment 48563
"Oc it" almost pee'd a lil bit...........
TURBS
Old 03-27-2014, 11:27 AM   #12
jonrjen's Avatar
Attachment 48562
Attachment 48563
Excellent, Thank you.
Old 03-27-2014, 11:28 AM   #13
jonrjen's Avatar
TURBS
Funny you should bring that up, next I will be installing the toilet paper holder.
vent
