Old 03-15-2015, 11:08 AM   #1
Dumb Noob Cable Question
Used our new 15 Grey Wolf for the 1st time and hooked up cable TV from the park to our trailer but could not get those channels on our tv only the digital broadcast channels from the antenna. Tried using a/v cables from the outlets above the TV and tried all the tvs inputs but to no avail. What did we do wrong?
Groy1889 is offline   Reply With Quote
Old 03-15-2015, 11:29 AM   #2
cdangel0's Avatar
Sounds like you have to change the input on the TV's settings. Set the input to "Cable" and do a channel scan.
Craig & Lynn D'Angelo
Delaware
cdangel0 is offline   Reply With Quote
Old 03-15-2015, 11:34 AM   #3
Eric F.'s Avatar
There should be a button on the panel where you plug the tv cable to the wall. I believe that button switches the panel from the tv antenna to the cable coming in from the outside.
Eric F.
2015 Flagstaff Shamrock 233S
2012 Ford F250
Eric F. is offline   Reply With Quote
Old 03-16-2015, 05:14 AM   #4
searay245se's Avatar
Turn off the ant booster when hooked to cable hook up and change from air to cable in the tv menu.
Jeff & Debbie
2015 Tracer Air 255
2015 Ram Laramie Power Wagon 2500
searay245se is offline   Reply With Quote
Old 03-16-2015, 11:55 AM   #5
Had same problem with our 29RE......Splitter was defective!!!!!!!
Jim in Halifax is offline   Reply With Quote
Old 03-16-2015, 11:59 AM   #6
Ret E-9 Anchor-clanker
donanddona's Avatar
We rescan every RV campground that has cable. And yes you should not have the LED on for the antenna switch over button..
donanddona is offline   Reply With Quote
Old 03-16-2015, 07:28 PM   #7
nikita's Avatar
Yeah - turn off the little green light for Antenna. Program tv for cable and do the channel scan.
Nikita
2011 Chevy Silverado Diesel 2500HD
2015 Sabre 33 RETS 5th Wheel
nikita is offline   Reply With Quote
