Old 07-11-2016, 12:52 PM   #1
Hugeez's Avatar
Dump Station Advice
Does anyone use anything to put under the sewer hose to keep the hose at an optimum angle when dumping at dump stations. I don't want to take too much time when people are lining up behind me but it seems I have to assist the sewer hose while it is draining to empty the tanks. This last weekend while dumping our galley tank, the hose came unattached from the fitting. Soooooo glad I wasn't dumping the black tank. Any ideas or help would be appreciated.
2015 Puma 29RBKS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
Hugeez is offline   Reply With Quote
Old 07-11-2016, 01:14 PM   #2
Alot of people, including myself use one of these.
https://www.amazon.com/gp/aw/d/B0006...r+hose+support
Sent from my SM-G900V using Tapatalk
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 07-11-2016, 03:14 PM   #3
waiter21's Avatar
If I'm hooked up at my camping spot, I use the slinky thing that Tim referenced to elevate the hose. (NOTE - Many RV parks / Campgrounds require them)
However, at the dump station, I just let it lay on the ground. I dump the black first, when its empty, I walk the hose to make sure its drained. i.e. Lift the hose near the MH to form a hump, then walk that hump to the sewer to drain the contents of the hose. Leave the drain valve open on the MH while walking the hose so the hose can vent back through the MH system.
I then close the black valve and repeat the process with the grey.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-11-2016, 03:21 PM   #4
Hugeez's Avatar
That's exactly what I do. I guess I need to get a better hose that does not separate from the fitting. I think I might try a sewer hose support but thought others lined behind me might not appreciate the extra time.
2015 Puma 29RBKS
E2 WDH
USN 86-92
Old 07-11-2016, 03:25 PM   #5
We usually dump at home with a Flojet. I am dumping at a CG I:
  1. let the hose lay on the ground
  2. dump the tanks from dirtiest to cleanest (black-galley-grey)
  3. close the valves
  4. wait a tic for the last of the drips to enter the hose
  5. disconnect the hose
  6. lift the trailer end and walk the last of the contents down the drain
  7. rinse and stow the hose
  8. cap the drain
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 07-11-2016, 10:02 PM   #6
joforbess's Avatar
I am using a pvc rain gutter I bought at Home Depot. I had to cut it in half to fit in the storage compartment but it helps to raise the hose and keeps it at a good angle to flow towards the drain.
2014 Salem 27RKSS - 2012 F150.
2012 Ford F150
2014 Salem 27RKSS
joforbess is offline   Reply With Quote
Old 07-11-2016, 10:13 PM   #7
Mr Havercamp's Avatar
  3. close the valves
  8. cap the drain
Thats about the same way we have always done it. No need for hose racks and other contraptions at a dump station...........gravity works.
I have yet to see a dump station where the inlet is higher than your tank outlet and that go's here in PA also, where I could show you lots of dump stations that are also on slight grades one way or the other.
Mr Havercamp is offline   Reply With Quote
Old 07-12-2016, 02:38 PM   #8
  3. close the valves
  8. cap the drain
Just bought a Flojet myself and after 1 use I can see this is going to be one of the best purchases I have made. Used it to empty the blank tank into my cleanout at home and it works great. I am going to use it to pump into my portable tank while still in the bed of the truck and to pump into a dump station if needed. I can see using it at a CG also and eliminate the need for using a sewer hose almost completely. I hard wired it to my fuse panel and ran the power to a storage compartment next to my sewer connection.
FloJet Portable RV Waste Pump System (Limited Number Available at This Price) - Waste Pumps (Macerators) - Plumbing
Brewhedd is offline   Reply With Quote
