Old 09-26-2016, 04:44 PM   #1
Dump Station at home, is it possible?
Is it possible to create a dump station in my back yard? I have a septic tank system underground in my backyard already so why not add a dump station? (I am not sure that I would want to empty it into the existing septic tank because that would be 30 gallons rushing into a tank that might overwhelm it and potentially cause septic system failure?)
One of the reasons I can think that it would be useful would be that it would come in handy for "dry camping" without having to stop at an RV park and pay for a dump station before returning home. Or when that somewhat undesirable guest stops for a visit and you restrict them to staying in your trailer in the yard, lol.
deattoms is offline   Reply With Quote
Old 09-26-2016, 04:51 PM   #2
KennyGolub's Avatar
I use a macerated to drain my tanks directly into my septic tank with out problem.
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Northern Ohio
KennyGolub is offline   Reply With Quote
Old 09-26-2016, 04:54 PM   #3
gwj123's Avatar
We also used a macerator to dump into our septic with no issues.
2016 RAM Laramie 2500 CC 4x4 Cummins Turbo Diesel
2017 Forest River Wildwood X-Lite 254RLXL
gwj123 is offline   Reply With Quote
Old 09-26-2016, 05:01 PM   #4
When folks talk macerators they are talking about something like this. There are several different types on the market but this one gets good reviews.
SewerSolution® System, Boxed - Valterra.com | Valterra.com
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 09-26-2016, 05:08 PM   #5
Phat Phrog Stunt Crew
elind's Avatar
At our cottage I put a saddle T on the sewer pipe going into the septic tank. I installed a 3" PVC pipe to the T and put a screw cap at ground level. When I pull the RV out, I stop by the pipe and dump it. Other wise I have a honey wagon that I pull over to the tank when needed. I can dump all three tanks with no problem.
2014 Wildcat 327ck
2015 129 nites
2016 63 nites
elind is offline   Reply With Quote
Old 09-27-2016, 01:13 PM   #6
Failure is my business
I just use the cleanout fitting to dump ours into the septic. Volume-wise, when my wife takes a bath, there is a heck of a lot more water at once than what's left from my black tank after a trip and a few rinses.
Current vehicle list: 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilsteins!, 04 Dodge Ram SRT-10 40,000 miles, 97 F150 4x4 5.4L 238,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
2Evil4U is offline   Reply With Quote
Old 09-27-2016, 01:15 PM   #7
Flybob's Avatar
If you do this be careful what chemicals you use in your holding tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-27-2016, 01:39 PM   #8
This may be obvious, but I'm posting it because due to the locations of my septic tank and parking area at home, I couldn't add a dump station. Make sure your new connection goes into the input line to the tank, not the outlet line. If you connect to the outlet side you'll wind up with major smelly problems.
DrLewie
Flemington, NJ
2007 Cardinal 30W LE
2008 Ford F-250 Long Bed Diesel
Total of 21 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 09-27-2016, 01:40 PM   #9
NMWildcat's Avatar
Lots of folks do this with their septic tanks. As long as your leach field is in good shape you should have no problem.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-27-2016, 01:44 PM   #10
Some guy in back...
I have used the Sewer Solution for nearly 20 years with excellent results. it's fast, easy, small to store and very clean.
One caution, though, is that while it is a macerator, it's a water jet pump powered unit as opposed to an electrical pump device. The difference is that the SS will use water to pump and this is added to the flow of sewage while the electrical pump does not add any water.
For some sewer systems, the added water is a good thing, for others, maybe not so good.
My only data point came from a maintenance guy at a park several years ago, a modern place on a septic system. he said the added water was a good thing and not to worry about it. YMMV
Cheers!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
