Old 06-28-2015, 09:20 AM   #21
Batts-toy's Avatar
Originally Posted by Wolverine 1945 View Post
Our Sunseeker 2500ts has a Black Tank Flush on the passengers side,,,
And the Flush valves are on the drivers side ???
The question marks in your post makes me think you are asking why, the flush valve is on the same side as your tank drain for convenience so you don't have to walk around the MH to open and close. The flush line on the passenger side is so the spray nozzle on the flush line will run towards the drain when flushing pushing solids across the tank. If I assumed wrong about your post please clarify.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 06-29-2015, 05:17 AM   #22
Wolverine 1945's Avatar
The Black Tank Flush is new to us,,, in the past I used a toilet wand on our Flagstaff,,, after we got home,,, flushed it in the yard...
I guess the ? marks are because I have never been to a Dump Station where the hose would reach the other side of the Sunseeker !!!
I do understand what you are saying about flushing to the drain valve Batts-toy !!!
Thanks for the reply !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-29-2015, 05:44 AM   #23
Originally Posted by fonzie View Post
Fonzie is headed in the right direction! Buy (2) Water Thiefs,keep (1) for Fresh Water and (1) Separated for ? Water! You will also need (Hose Clamps) because the (Water Thiefs) are (NOT) made for Pressure applications! There is a Time when you will need Them! Youroo!!
water
