Old 03-13-2013, 09:57 AM   #11
Fulltime family RVer
Originally Posted by grayfox View Post
Different strokes for different folks... there must be something in the air in Columbia... just kidding. I grew up in Howard County before it was Columbia.
Before we get too far offtopic - I'm a HoCo/Columbia transport. I grew up in southern/central Pennsylvania and only moved here about 12 years ago (wow, can't believe it's been that long!). So, I blame the hills of PA for my unique-ness.
And now, everyone... back on topic.
ependydad is online now   Reply With Quote
Old 03-13-2013, 10:13 AM   #12
Just one quick reply. I'm located in S/CP myself. Artemas PA.
grayfox is offline   Reply With Quote
Old 03-13-2013, 12:20 PM   #13
sself1219's Avatar
My grandparents live close to me and have camped all their married lives(celebrating 50 years this Saturday ) My grandfather had a sewer access installed in his front yard at the edge of the street so he can pull his 5er up and dump the tank if needed when they get home from camping if they can't use the dump station at the campground. I use it some times if I don't have access to a dump station or need to slosh the tank around to get the solids to dissolve.
Stephen
2004 Surveyor SV 261T
2011 Nissan Armada
sself1219 is offline   Reply With Quote
Old 03-13-2013, 12:34 PM   #14
Witch Doctor's Avatar
I'm a Zoning Adm. in the Town where I live right now, It would be a big fine $$$$$ using a cleanout to dump here. It is always best to check, some city's or towns permit it but here it is a NO NO....
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-13-2013, 12:44 PM   #15
B47
I wonder why the fine - the sewage is still going to the septic tank or sewer system regardless of how it gets there.
Old 03-13-2013, 03:52 PM   #16
In town you are required to be hooked to the Town sewer system, You pay by the # of gals used by the water bill. You and I both know that all water that go'd through a meter is not going down the sewer, such as watering your grass. Without a town adding a meter to monitor the sewage use they use the water consumption this is very typical ord. in any town with a sewer plant. Now saying that if you have a septic system at your home that would be different. You could dump what you want into it. What was said that a clean-out was installed at the street, I do not know why a clean out would be at the street if you where on a septic system? being most septic systems are behind the house not under the street. All I'm saying is that you need to check out your situation and hook-up to either a Town system or septic....A lot of people do that without knowing the law. If caught here in Clarksville it's a misdemeanor and a large fine. I was just at a call where a complint was that a guy bought a new TT and someone seen a hose connected to the TT. Well anyway I found that it was a water hose and not sewer drain. ......
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-13-2013, 04:40 PM   #17
B47
Makes sense to me now
thanks for the explanation.
Old 03-13-2013, 05:04 PM   #18
Mountainmanbob's Avatar
Originally Posted by herk7769 View Post
Use a clear elbow and ANY brown tint means there is more to come.
just started using a clear elbow a while back
makes it all so easy
to see exactly what is going on
or
should I say
going down
Mountainman
Mountainmanbob is offline   Reply With Quote
