Old 01-17-2016, 11:37 AM   #41
Before settling on a new truck or small fiver go talk to your dealer and explain the situation to them. The fleet manager is a good place to start as they tend to know about trucks. Have him/her explain exactly the differences between your 2500 and a 3500. You will find there is very little difference. Ask the cost to add the rear suspension change to your truck or even if you need it. You have plenty of rear axle capacity available. The 10K GVWR is more of a licensing/registration number than a number that represents the true capabilities of your truck. It can't hurt to talk to a more knowledgeable person than you can find on this forum.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
lbrjet is online now   Reply With Quote
Old 01-17-2016, 11:47 AM   #42
Lvn2tvl's Avatar
So the dealer may be able to increase my payload limit?
2018 Cedar Creek Silverback 29IK
16 Silverado 3500 HD 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
Old 01-17-2016, 01:47 PM   #43
Here's the simple version:
GVWR is how much the naked truck can carry in the bed and cab, with no assistance from external axles. It is limited by the combined axle capacities, brakes and the transmission/drive train. Should always be less than, or equal to, the sum of the axle ratings.
GCVWR is how much the truck and tow can safely move, assuming assistance from towed axles and brakes. Most often, this is limited by the transmission/drive train. You can look up this limitation for all the Allisons on their web site.
GAWR is how much the axle can carry and can be limited by the axle itself, the tires, or the tire rims.
Trouble comes when you have the hybrid, as in a 5th wheel, which puts a large weight in the bed in addition to the tow load. Despite numerous protests to the contrary, here the operable parameters are your GCVWR and the rear GAWR. You don't need to worry the GVWR if the rear GAWR is good because the truck doesn't have to brake the load. Folks that worry the GVWR towing 5th wheels are either confused, looking for something to worry about, or desire to gloat because their rigs are also good for the GVWR.
A side note. For the diesels, most of the 1 ton and 3/4 ton axles are the same, design being controlled by the torque, not the carried load. Difference is in the hubs, rims and tires, so there's a little room for upgrading via tire and rims. However, this may not be true of the gas engine axles.
RubberNail is offline   Reply With Quote
Old 01-17-2016, 02:23 PM   #44
Crusadernoob's Avatar
No, a dealer can't increase a payload limit. That is set by the manufacturer, no matter what increase in springs, airbags you are set to what your door sticker is.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 01-17-2016, 02:39 PM   #45
Lvn2tvl's Avatar
Which goes back to read. read..read the specific specs. before you pay any thing on a new vehicle. Specs are specs and nothing can be done to increase any of them. However you can do just one thing to drop these same numbers.
Bob & Cindy
Old 01-17-2016, 02:47 PM   #46
SYE
SYE's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Finding an honest dealer, they will tell you what you want to hear, just to get your money.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 01-17-2016, 03:02 PM   #47
Lvn2tvl's Avatar
X2 But l'm never buying another vehicle that I don't know what the exact (not advertised or told) weight specs are without an expected weight characteristics exclusion attached to it. OK I'm off my soapbox, sorry. Thanks for listening. Hopefully you cannot tell that I'm upset with myself for not knowing this before I spent $50K+ on my newer TV.
Bob & Cindy
Old 01-17-2016, 04:09 PM   #48
I know I'll get jumped on but I just don't see any difference between a 2500 Silverado and a 3500 Silverado. The most important thing to remember is that no one is ever going to check your weight on your truck. It's your truck and DOT is not going to stop you and check your weights. If you are worried about weights don't weigh your truck. I would bet that 90 percent of the campers that's camping have never weighed there trucks. There is no way DOT can weigh all the campers.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 01-17-2016, 04:34 PM   #49
Lvn2tvl's Avatar
Sorry but I cannot do that. I can't afford the legal side if having to deal with property or personal damages if I have a problem. Keep in mind that all of my specs are easily within limits of my current TV. I just started looking at newer 5er's and wanted to know what size I could buy that will work with my existing TV instead of the other way around.
Bob & Cindy
Old 01-17-2016, 04:37 PM   #50
Kenny kustom's Avatar
My 3500 has a GVWR of 11,500. This means, in Canada, i MUST pull into all weigh stations. They will weigh, and check my GVWR.
I can be fined for being over.
I have mentioned this here before, and received alot of arguments about it, but its true and the law. So i do it.
axle, weight
